dbotos
In the market for a new muffler for a 1991 LB1914. OEM replacement is $400 and I'm not paying that. With the heat shield removed, the muffler is about 13 inches long by about 3.375 inches in diameter. Peering into the bottom end of the muffler (where the elbow that bolts to the exhaust manifold was formerly welded to the muffler), I see what looks like remnants of an inner perforated tube (round-hole perforations) and also whitish crystal looking stuff that I'm assuming is fiberglass that was behind the perforated metal.
Which would make it a glasspack muffler like this:
Thrush® Glasspack Muffler
What are people's experiences with this type of muffler on a diesel? Based on how sooty it is inside there, I worry that the fiberglass packing (and possibly the holes in the perforated inner tube) would get clogged up with soot relatively quickly and the muffler would become effectively a soot-lined pipe. What about baffle-type mufflers for a small diesel?
The hole in the square-flange plate of the elbow that bolts up to the manifold is about 1.313 inches and the outlet pipe is a piece of fence top rail that measures 1.315 inches OD. I added the latter to extend it above my canopy and put a flapper on it.
Thanks,
David
P.S. The muffler in the pic is OEM, possibly the original one that came on the tractor.
Thanks,
David
