How many acres can I mow per hour?
   / How many acres can I mow per hour? #12
Well according to the chart if you are using a 6' mower at the speed you claim you are cutting close to an acre and a half per hour whether it's smooth or rough, so I don't understand why the chart is only good for someone cutting smooth ground, help me understand.
"Obstacles" is I guess what I would call them. If I were mowing in a straight line that chart would work. But I'm having to make detours around bad spots so that adds to miles driven but not actual miles mowed because part of the time the mower is lifted up and not mowing, or going over areas already mowed.
Yeah, I don't know that it takes in account for trees , brush piles, rocks, trash piles, etc, I think it's probably just giving an idea that with a certain width mower and you holding a set MPH mowing grass and weeds that you can expect to get X number of acres mowed per hour, I have checked this chart a couple of different times and have found it to be fairly accurate for what I was mowing.
   / How many acres can I mow per hour? #15
Statistical mowing charts are pointless. Nobody is mowing a flat straight line with no turns and a 100% steady speed. Every turn adds time. Every variation in speed adds/decreases time.
Okay, you could mow in a circle if you wanted to nothing about the mowing chart says you have to mow in a straight line and there is some compensation in the chart for overlap and other things, it's just a general guide to give someone an idea of how much ground they are covering per hour.
   / How many acres can I mow per hour? #17
My point is the mowing chart is not practical in the real world. It's using static values that do not fit the reality of the majority of environments. Sure, it's a possibility but it's not a probability.
   / How many acres can I mow per hour? #18
Age gives you a different perspective. I'm not a business. I get paid the same however long it takes me to mow my own place. I'm not in competition with myself or anyone else. :giggle:
   / How many acres can I mow per hour? #19
It takes as long as it takes is the way I look at it. I do have a good neighbor I help out from time to time and only charge him the fuel used. If I were to do mowing for anyone else it would be for pay. It would be an agreed upon hourly rate starting when I left the house and ending when I got home. Again taking as long as it takes, otherwise find someone else to do it, I don't need the headaches, hassles or the money.
That's funny, I just did 30 acres today and was within 20 minutes of what the chart said, so it was definitely practical in the real world for me, I do a good bit of mowing and tractor work for others so I use it occasionaliy when someone insist on an hourly rate, but in your situation it probably doesn't apply to you.
2017 Ford F-550 (A55973)
2017 Ford F-550...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
1762 (A58375)
1762 (A58375)
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
