Huskee tiller won't start
/ Huskee tiller won't start #1
jameswow67at123
FORD 800
My husker tiller won't start, Sorry if I'm putting this in the wrong place but its a emergency, we need to get our garden in. It will run off starter fluid but not gas, any help would be apperatited!
/ Huskee tiller won't start #2
Probably a good bet it's the fuel pump diaphragm. A good mower shop should have them in stock, probably around $2.00. I get them by the 10 pack off ebay usually for +- 75 cents each. Pays to have them on hand if you run ethanol laced fuel. Alcohol makes them stiff and won't pump fuel.
It's behind a rectangle plate on the side of the carb. Most you have to remove the air filter housing, and the rubber tube to get to them easily. Old screw were small Phillips head, new one's are like a #15 Torx. Remove plate and pull off. When removing diaphragm, be careful because there is a spring behind it and a cap for the spring to push against the diaphragm so as not to damage.
For a first timer, probably a 25 minute fix if you have the part & tools. After doing 15 or 20 of them 15 minute fix and that's taking a smoke break.
Remove the old one and take it with you to match a new one. It will probably be somewhat stiff. The new one is really limber and will fold over in half holding on to one end. There are holes that go over guide pins, so it's an easy fix.
/ Huskee tiller won't start #3
If applicable, remove the carb. Float bowl and look for debris. Possibly a jet or port clogged up. Ethanol fuel left in these small engines tend to gum things up. I’ve gone to non ethanol fuel for my small engines that don’t get used regularly.
/ Huskee tiller won't start #4
Was the fuel pump the problem??
willy
/ Huskee tiller won't start #5
I feel like he needs to check if it’s firing before overhauling to fuel system. Just put a spark checker on the plug
/ Huskee tiller won't start #6
OP posted it will run on starting fluid, but not start on gas. That's why I'm betting it's the pump diaphragm.
2022 EZ-GO ELITE...
speed limit sign (A61572)
speed limit sign...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
SQUARE FUEL TANP & HAND PUMP (A63291)
SQUARE FUEL TANP &...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
John Deere 2155 (A62177)
John Deere 2155...
