Good morning!!!!
   / Good morning!!!! #191,141
good morning all
cooler morning in the 50's out, high of 77 today, should be a beautiful day
off early to an important doc appt, new ENT, hope to get some help with tinnitus/Menieres.
more tests, more tests.
then home to work in garden. Going to pick last of lettuce and rip out the poor growing radishes.
Then have some squash and melons to plant in their place. I really need to find some diatomaceous earth
to put in the soil, too many veggie biters in there
   / Good morning!!!! #191,142
49F clear sky mis 70's for high.
Plans for today...4 hours at part store,afternoon level clean up around stump dump than putter.
Enjoy your day all.
   / Good morning!!!! #191,143
51 this morning high in upper 70s one patch left then parking lot sugar level back in range after running out of insulin.
Good luck at docs Drew
Prayers for all our Country
   / Good morning!!!! #191,144
Morning all!
44 going to a low humidity 74!
Will be a great outside day!
First stop this morning will be at one of my sisters to see about getting her little Kioti running. It has been parked since last October. She also wants my string trimmer for a bit. After that I have grass that needs cutting and deck rails to prep for paint.
Couple of small projects in the shop completed but no pics at the moment.
Hope everyone stays safe and healthy!
   / Good morning!!!! #191,145
Good Morning
52° and sunny, high of 70 forecast with a gentle breeze.
A perfect day to work outside.
Yesterday’s trip went well, one of those rare days when the weather was great on the entire east coast. It still killed the whole day when you factor in the drive to the airport and back. I put the trash and recycling down to the street, only to realize when I went through my emails that the pickup was pushed back a day due to the Memorial Day holiday. So I went down and brought them back up.
Today I’m putting in the plumbing drains that go under the slab, glad it’s a great day to work outside.
I’m going to try to remember to capture a picture from the “construction cam” every morning, then put them together into a time lapse when it’s done. Here is this morning.
   / Good morning!!!! #191,146
good morning, colder 47 going to 74 Hyper heat turned on
Busy day, changed another hydraulic hose on the tractor that was abraded. 50 dollars for a short hose but made it a little longer to reroute it out of harms way
Moved another section of the upper area. Changed the mower belt for the ZD331. Was able to do it without taken the deck off or remove the gearbox. Man that spring for the idler is very strong but used a ratcheting load strap to pull the idler arm enough to get slack to get the belt off. Off course one of the bolts fell down on the underside of the deck so it was tricky without a second person to get it to stay long enough to get the nut on top of the deck. Also changed the oil on the gearbox.
Why do they make it so the only way to drain it it runs out on top of the deck. But sucking it out gets most of it.
Drew this a lot testing. Hope they will help in figuring out what is going on. Hope for the best
Buppies your last A1C results came back very good. You must be living right
David hope the tractor will not stall again. If it does it sounds like time for the temporary tank test
   / Good morning!!!! #191,147
56 outside right now, heading to upper 70's. Should be a really nice day. Lots of pastures to cut today and this weekend.
Time for the morning chores.
Hope all have a great start to the day. Be safe.
   / Good morning!!!! #191,148
Good morning! A glorious rainy cool morning at 64˚F, 1.1" rain, variable winds, heading to only the mid 80s.
Said a 2 week goodby to PT yesterday after yesterday's session, to do the big move. The wood floor, which was confirmed solid mesquite and not a laminate will be refurbished today, it does not need re-sanding only a buffing and refinishing to get out the dog claw scratches of the last owner. We will continue to identify the items that we do not need for the next 2 weeks and box them and take them to the new house. It is a whole lot easier moving when moving to a bigger house. The movers and their big truck have been scheduled to move the furniture.
Another round of rain might hit us this afternoon. Nice.
   / Good morning!!!! #191,149
Good Morning
do the plumbing drains connect into the existing septic system?
   / Good morning!!!! #191,150
Morning all, 53 going to 77 and sunny.
Just worked on the pool yesterday.
fawns are back today.
Drew - Hope the new doc works out. my radishes have great leaves, but super tiny roots.
Who knows what'll happen today.
Be well,
Seems I am now raising micro radishes
The fawns that snuck up on the dog and I the other day. Out playing tag in the front yard.
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A58018)
2006 MAC TRI AXLE...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
SHOPBUILT S/A METAL TRAILER (A52708)
SHOPBUILT S/A...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2021 CTS HRD 37LW 34 Ton T/A End Dump Trailer (A55973)
2021 CTS HRD 37LW...
2000 Sterling L7501 T/A Drill Rig Truck (A55973)
2000 Sterling...
