sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,422
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
On the ZT wanted to use impact and torque stick for the blade screws but could not raise it high enough for clearance.
The blocking of the blades would work at times but slip at other times on the spindle
Putting a wrench on the pulleys and using torque wrench would work. The center with the gearbox used a large screw driver on the drive shaft to block it.
Found a setting on the Milwaukee impact that is close to required torque and is using that now. Much faster
With mower dismounted, carefully placing pipe wrench on the gear box shaft works well. Like you said, just not enough space to grab anything.
