1920 Ford Hydraulic pump New install I need Help. It won’t Prime
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #21
I would not go much over 5 PSI and have used exhaust from shop vac for this purpose. Go to high and you start to damage seals, potentially crack a casting due to large surface area the pressure is acting on, etc.
Start real low, a compressor or nitrogen tank is way too much pressure.
Consider that a vacuum cleaner pulls about 3 psi of vacuum.... that is what it takes to lift a column of water up a hose about 80 inches.
I realize that doesn't mean that the output side of the vacuum cleaner is the same psi, but it gives a ballpark idea.
I said earlier 5 to 20 psi. Now I'm thinking way less is better.... maybe 2 to 10 psi.
Putting a pressure gauge on the vent tube is probably a smart move. Hardware store gauges and some tubing ought to do.
Or if you have any inert gas for welding, you already have the right setup with psi adjustable.
rScotty
Sounds great I’ll try lower pressure just in case I do have a couple shop vacs that I can try
What was the original pump failure? Did you replace the hyd filter, and/or any other screen in the system?
When I bought the tractor, the tractor had water in the transmission area so all the hydraulic fluid was contaminated. I have another posting of me cleaning the transmission cleaning it with diesel. I cleaned everything out changed all the filters cleaned everything.
Transmission was spot less.
Thanks for the info
When I said pressurize the case, I was thinking of putting the air nozzle in the hole surrounded by a rag; not real a positive seal. It won't take much to prime if the pump is good.
Thank you for the info
Gentlemen many thanks to all. After trying the vacuum trick on the transmission the unit primed and started working instantly. Thank you guys. Hydraulics are back 100%
SKIDDED FRAC TANK (A58216)
SKIDDED FRAC TANK...
2013 Kubota RTV900 (A57149)
2013 Kubota RTV900...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
1987 International S1900 Fuel Truck (A55272)
1987 International...
