1920 Ford Hydraulic pump New install I need Help. It won’t Prime
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #11
I'd be a bit leery of pressure in the case, anything over a few inches of water pressure can blow or damage seals enough to start leaks. There is approximately 27.7 inches of water pressure per pound of pressure.
I'd be more inclined to remove a discharge hose to remove any back pressure in the system and or use a shop vac to draw oil into and through the pump to prime it.
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #12
On my IH 424 I always have to crack the output on the hydraulic pump in order to get it to pull hydraulic oil into and out of the pump due to air lock.
The filling of the pump prior to installation is a good idea and using a shop vacuum to suck oil into the pump may work too.
I think that pressurizing the transmission sump is a great idea.... don't forget to plug the transmission sump vent tube - where ever it is.
A little pressure might also prime the system if the output from the pump is loosened. And it may also show up any suction leaks, which is something I've never found a way to do.
My hat's off to Tractor Tech for coming up with the idea.
How much pressure do you guys think would be necessary?
I'd say to start with low pressure/high volume...with the goal of getting the air in the sumpn up to somewhere in the 5 to 20 psi range.
My guess is that's about what the output of a vacuum cleaner puts out. No harm in starting low.
rScotty
Thank you for reminding me of the transmission sump vent, which I completely forgot about and I will be trying it first with a vacuum pump because my compressor is damaged and the only thing I have since I do refrigeration is nitrogen tanks, but I can regulated up to whatever psi I need. I will keep you guys posted later on today after work what happens thank you.
That is awesome. Another great idea to try out today.
I tried cracking the output, but nothing came out. I did not try the vacuum pump thank you for the idea
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #16
When I did it the tractor was running and made a mess.
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #17
Below 10 psi is what I would recommend. I don't think the seals would be harmed at that pressure. I wouldn't worry about the vent
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #18
Start real low, a compressor or nitrogen tank is way too much pressure.
Consider that a vacuum cleaner pulls about 3 psi of vacuum.... that is what it takes to lift a column of water up a hose about 80 inches.
I realize that doesn't mean that the output side of the vacuum cleaner is the same psi, but it gives a ballpark idea.
I said earlier 5 to 20 psi. Now I'm thinking way less is better.... maybe 2 to 10 psi.
Putting a pressure gauge on the vent tube is probably a smart move. Hardware store gauges and some tubing ought to do.
Or if you have any inert gas for welding, you already have the right setup with psi adjustable.
rScotty
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #19
Hi everyone I just installed a new pump after mine failed. I had zero psi and I cleaned pressure relief. I replaced oil and seals on the metal lines.
So I installed a new pump and it won’t prime or do anything I need some help. Do any of you guys have any pointer what I need to do. I followed instructions added new oil and replaced filter and let tractor idle. But nothing
What was the original pump failure? Did you replace the hyd filter, and/or any other screen in the system?
   / 1920 Ford Hydraulic pump New install I need Help. It won’t Prime #20
When I said pressurize the case, I was thinking of putting the air nozzle in the hole surrounded by a rag; not real a positive seal. It won't take much to prime if the pump is good.
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
2014 Ford Escape SE SUV (A56859)
2014 Ford Escape...
1995 FORD LTL9000 FLAT TOP DAYCAB ROAD TRACTOR (A58375)
1995 FORD LTL9000...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2016 Bobcat S740 (A57148)
2016 Bobcat S740...
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
