The Original Tractor Relief Tool - Easier Hydraulic Connections
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #31
Welding is such a handy skill, good on your ingenuity!
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #33
It could use a nut on the adjustment shaft to prevent it from being turned down too far and damaging the fitting.
I did this on one of my fittings by not paying close enough attention to what I was doing.
Yes, it was my fault, however in doing so I also discovered that the fitting was nowhere near as well constructed as the one I replaced it with.
I had some anxious moments wondering why my grapple would open extremely slowly and then drift close. One fitting I damaged and the other went bad - the hydraulic fitting vendor went on my list of what not to buy.
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #34
I ordered a set of these today..
After nearly pulling a muscle and then getting hot hydro shot in my face… this is easier than a burn..
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #35
Question.. has anyone put a vinyl hose
On the output fitting to keep from spilling or shooting it everywhere?
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #36
I have not done it myself, but I've seen it done, absolutely.
You can if you wish, that is why the barbed fitting.
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #38
I don’t see any for the flat faced skid steer type used on attachments like the grapple on my loader (and of course my CTL). Those are the worst.
   / The Original Tractor Relief Tool - Easier Hydraulic Connections #39
Here is a simple one I made. A nut welded to a piece of bent up light steel. You could do it w/o welding but you need a wrench to hold the nut. I am using it to hold the connector open to drain the yucky oil from an old plow I bought.
gg
Have for Skid Steer Flat Face ISO 16028 fittings now.
2015 Puma TUK-13030HGE Air Compressor (A55973)
2015 Puma...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
John Deere 5115M (A57148)
John Deere 5115M...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
