TX1510 replacement water pump
/ TX1510 replacement water pump #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Hi folks the replacement water pump for my TX1510 (K3B Mitsubishi Engine)has a small outlet pipe (see picture bottom right) whereas the existing one does not(its got a 'plug' screwed into the opening - does anyone know whether this needs blanking off or attaching to something?
/ TX1510 replacement water pump #2
Your water pump looks similar to the one on my Mitsubishi D2350. That tractor did have a small coolant line going "somewhere" back the right side of the engine. If your tractor doesn't have the line you can probably just plug that hole on the water pump. The older Japanese tractors had many parts in common regardless of manufacturer.
/ TX1510 replacement water pump #3
Just unscrew the pipe ripple and fit with plug. Like mentioned, pumps on Japanese tractors fit across a lot of makes.
Many thanks
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A64556)
2017 Ford F-350...
2022 EZ-GO ELITE...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
2012 Toyota Camry Sedan (A64557)
2012 Toyota Camry...
