Good morning!!!!
/ Good morning!!!! #190,821
Drinking cup of hot coffee. 45° with clear skies this morning. Heading to 82° with a few clouds. Grocery shopping was good. Returned home and put them away. Did some Put a few more yard ornaments out. Then enjoy more time on back porch. No plans for today.
Stopping by for a drink of water.
Everyone stay safe and well.
Good Morning All.
/ Good morning!!!! #190,822
Can’t believe Code changed to R49, that’s crazy. Air infiltration is a bigger issue than R value. I might have to look at rafters, didn’t want to go that route. I’m bummed out.
That’s what made urethane foam worth the expense, I was able to use smaller lumber, I can get R21 in a 2x4 wall as well.
Did you verify that your municipality requires compliance to the IECC code?
/ Good morning!!!! #190,823
Good Morning
63° with a high in the low 80’s under partly cloudy skies becoming clear by late morning.
Yesterday was another busy and productive day on the construction site. The foundation walls are all formed up, squared and level. I was impresssd with how precise they get them.
I had to leave around noon to go to Portland, when I got home I checked the elevation of the sleeve they placed in the wall for the sewer line to exit the foundation and determined that it should be 4” lower to give the proper fall to the tank.
They placed it where we discussed, but the elevations were only eyeballed. The walls get poured today, so it’s not too late to change it.
The downside is that I won’t be here for the pour, I’m off to Palm Beach early this morning. The good news is that I’ll be back by 2 or so. This should be my last trip for a little while, I’m only doing the ones where my presence is requested by the client so I can be here for the construction.
/ Good morning!!!! #190,824
good morning all
nice warm dry day up into mid 80s today, good day for Popgadget's
concrete to dry.
early day and a long one.
Have to be at school at 6:30am to have pancake griddles hot for 7am rush of kids.
then off to local hospital to see MIL, BIL called last night, she is in for observation at 97, apparently
too anemic. So I'll go visit her later this morning.
hope you all have a nice day
/ Good morning!!!! #190,827
49F clear sky upper 70"s for high.
Outside chores done E muffin time. :)
Plans for today...4 hours at part store,afternoon critter food stop than give lawn good old fashion mowing.
Enjoy your day all.
/ Good morning!!!! #190,829
66 and cloudy/damp. Not raining yet. 81 high.
Buppies, glad your health is improving and you got the cancers off your skin.
Mostly, hope you have a good visit with stepson. Sounds like you had a long drive.
L4N, I bet it's good to be home. Take it slow and easy.
Got a hike in yesterday between puppy times...not much else besides swapping the bucket in place of the grapple on the FEL.
/ Good morning!!!! #190,830
Started cleaning up my cabin plans, and ended up spending the day. I haven't caught up yet on todays posts, about 50 behind it seems. Then just as I finished tonight, I'm thinking I might swap the front side, so all water is in a concentrated area. Also, if I do put in basement, stairs will need to come out of Family room space to the right as you go in front door, so would rather make kitchen smaller then the alternative. Plus, I found way to fit the laundry inside, so don't need the ugly box on the back. If I do basement, water heater can go downstairs.
I put SIPs on another layer and shut it off, probably won't do because of the price difference. Actually layed out most of the studs in the walls on another layer I have turned off, not done with that, but that will be helpful when framing. I'm excited about this version.
I would have the front door swing the other way.
/ Good morning!!!! #190,831
Good morning! 76˚F heading to the low 90s, S wind, partly cloudy.
The tile floors are polished and sealed The workers are finished. Yesterday was light bulb replacement day with a run to Costco and two runs to Home Depot. I thought I was finished but found several other odd bulbs to replace today. The very old people that lived in the house before did very little maintenance.
We cleaned the baffles in the stovetop hood vent, had to set them outside and let oven cleaner soak, then blast them with a hose. Under the grease they still had the protective blue film on them, which we removed, so now they look like new. They left a set of long horns on top of the stove, will keep them, but glad they took the ram head out of the hallway.
Today our old house goes on the market.
/ Good morning!!!! #190,832
Good Morning,
Vt, 53 to start going to 76! Beautiful sunny day, low humidity but I have a lot of work to do before the rest of the gang gets here. The front lawn could be baled as hay its so high ! So it looks like I will end up cutting it twice.
Thomas, I truly hope everything goes well for your surgery !
Paul, the concrete work looks really good so far, and Dons suggestion about front door swing is good.
Dennis, is the top link on your Dads tractor adjusted properly ? I ask because it seems low in the back end even in the raised position.
Ken, your pool looks great, I am also thinking of power washing the stamped concrete around the perimeter and then re staining the pressed concrete, brick red. It has faded over the last 30 years !
We got up here about 7:30 last night, so 3 hour and 20 min drive. Traffic was light ! Unfortunately there is a dead animal under our deck, so will have to deal with that this morning ! Ugghh
Hope all have a great friday ! :) :)
/ Good morning!!!! #190,834
67 outside right now, heading to maybe 80. Rain expected.
No yard work yesterday. Met middle daughter for late lunch to celebrate her 30th. Ate at our fav restaurant, the sushi palace. The place has been around for over 20 years and it was packed yesterday. They know their fish and their service and prices have always been exemplary.
Today I think the wife and I will pay our respects to our Marine friends.
It will be a solemn weekend for us.
Hope all have a good day. Be safe.
/ Good morning!!!! #190,835
Good morning, the low is 44 and going to a high of 64°F. Wind WNW 10 mph. Mostly cloudy with 60% chance of showers.
Sugar first thing was 7.6, breakfast already down my neck along with 4 pills and one capsule. BP last evening was 115/60 with a pulse of 87. Almost half of what it was when I took the meat wagon ride. ;)
I gotta go back into town today and get a 'sharps' container and some fruit.
I am in the process of applying for disability through our Unemployment Insurance scheme. That'll pay me $602.oo/week for 26 weeks.
I am looking forward to watching the house build, Popgadget.
Have a safe day all
/ Good morning!!!! #190,837
fun morning flipping pancakes.
I got the less lively gluten free line, less takers.
the regular batter was thicker and fluffier.
got very hot back there, I had to leave a little early, come home and change
sweaty shirt and now waiting to hear about when to go visit MIL in hospital.
/ Good morning!!!! #190,838
Good Morning!!!! 59F @ 6:00AM. Sunshine and a few afternoon clouds. A stray shower or thunderstorm is possible. High 82F. Winds S at 10 to 15 mph.
Glad to read you're back home, Bill. Are you able to get around OK, and drive?
First coat of paint on the outside of the trailer took longer than I'd have liked, partially due to a surprise visit from the neighbor that was helping on the dent in the trailer hitch. He brought some punches, but the ends were too square to do the job. I found a piece of rebar laying under the office trailer and used a cutoff wheel in the angle grinder to round the end into a dome shape. That and a three pound hammer did the job. Finished the coat of paint and ran errands in town. By the time I got back it was pretty warm, but decided to put a second coat of paint on the trailer anyway. Paint skinned over in the roller tray, and the skin found its way onto the trailer. Looks a little rough, but it's just a trailer. The more paint, the merrier. And that was it for the day.
Just checked, and that fraudulent Temu charge posted yesterday, so now I get to do the dance with the bank to get it removed. Anybody else have issues with Temu?
Wire wheeling and Metal Prep on the inside of the trailer this morning, followed by some maintenance work on the tractor. Messick's order showed up in only two days!
TGIF gang...
/ Good morning!!!! #190,839
Morning all, 73 going to 86 and sunny.
Powerwashing the pool deck continues.
Found 2 hornets nests, hopefully deactivated them last night.
Need to mow after I finish pool deck. Back deck PW will need to wait so my back recovers!
Also need to change out garage springs and see if I can fix the garage door opener.
Did find some baby birds yesterday. Will leave the nest until they fly.
L4N is home, bet that is a huge relief!
Don - best of luck for the sale, hope it goes quick and well.
Rip - happy birthday to your daughter.
No wrecker yards local, anyway they are the $600 vs. $800.
Was thinking some kind of anchor bolt to expand in the empty center as the plastic piece that used to hold it together is in 2 parts, instead of the one. So nothing to hold the top to the bottom anymore and no way to buy that part as the rest of the mirror base can't be disassembled without damaging other parts.
Be well,
Luckily not blocking any screens or valves.
/ Good morning!!!! #190,840
they use the virginia uniform building code, which then references UBC or IECC. Until next Jan you can specify either 2018 or 2021, but must use 21 code after next january. Current version seems to say R30, if I'm reading it right. In Va for climate zones 3, 4 or 5, looks like remains R30 in the new code. ICC says 38,49,49 for zones 3-5. I might be OK.
I see you pouring foundation instead of block. I need to find a concrete guy down in va that does the forms. All of my house is done that way, even the garage frost walls. Are you slab on grade, or crawl space? VA is only 24" frost depth, and that's to bottom of footer. I like to go a little lower but with concrete prices will like to stay at minimum.
Your rebar looks like two #4 on chairs about a foot apart. I assume the stuck the vertical ones in the wet cement.
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
2017 Dodge Grand Caravan Van (A59231)
2017 Dodge Grand...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
2020 DRAGON ESP...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
