dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,683
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
On testing the pressure settings for a dual-crossover (cushion) valve:
The way to do it cheaply, without installing a high-pressure tee fitting at the end of the valve stack (power-beyond), is to first put a gauge on the AUX hose, as I showed above. Then operate the house motor in both directions with the bucket jammed into the ground, while simultaneously operating the AUX valve lever.
Note that a PB port on the main valve stack may not even be available.
I have not done this yet.
