Got asked to bid a very unusual project
   / Got asked to bid a very unusual project #381
Hey Jon,
Uhhhh I don’t know, why do you ask?
How do you “close a thread”?
Do you want to close it?
I was thinking leave it open should the log removal get underway. 🤷‍♂️
listen this a project you actually bid or are you removing debris on time and material basis
I was asked to bid it along with several other more mundane property improvements, including trucking away a large log pile and rebuilding about 200’ of washed out trail.
Priorities of the Customer keep changing and we have to change with them.
Great customer
   / Got asked to bid a very unusual project #383
Great customer
I imagine everytime their priorities change so does the price, it's nothing but good for your bottom line and bank account.
   / Got asked to bid a very unusual project #384
Consider a compressed air wand/probe, maybe augmented by driven water, to surgically destabilize the sandbar/mucky base of the pile when you get down into the embedded parts.
   / Got asked to bid a very unusual project #385
Good post. The first time I saw one of those in operation the operator was wearing what looked like a space suit. The blow back mud would cover him and they would periodically hose him off to cool him down and wash the mud off.
   / Got asked to bid a very unusual project #386
Good post. The first time I saw one of those in operation the operator was wearing what looked like a space suit. [Snip]
Thanks! Ive never seen one - didnt even know they existed as a product. I conceived and made one years ago to clean the dirt off stumps. Even with my small 15 CFM air capacity it shows you the beauty of having the ability to wield a "soft bomb on a stick". With their availability as a product it is hard to understand why several of them backed by hundreds of compressor horsepower were not used to free the ship stuck in the Suez canal.
-- Course yould need the Hulk or Paul Bunyan to wield it! A human operating through a mechanical manipulation and feedback system could do it. Developing the servo system could be a bit expen$ive I guess.
Wouldnt need anything of such capacity on Hay Dudes project. Id say ~100+ CFM from a nozzle at the end of a 1/2 pipe used from a platform suspended under the bridge would be ample, and controllable downward. The compressor would stay on land. :ninja::cool:
   / Got asked to bid a very unusual project #387
7.5 years ago, I was working on a vacuum excavation crew, doing soft digs on utilities, using compressed air, and the vac hose. Air full blast, probbing for an 8" gas main; in some mucky, wet ground, with mixed layers of hard pan. I got the air Lance clogged, and went to pull it out, without turning the air off. As I pull the 16 ft air Lance up, into the black, cold, water and muck, the clog releases; Drenching me head to toe in cold black much; and the white Ram 5500 vac truck. End of the day, I take the vac truck home; strip down to boxers on the porch and take a shower. Wife gets home; walks in the the door, and first words "please tell me that's not ****" :)
   / Got asked to bid a very unusual project #388
:):D Thatll do it! To resist clogging the orifice can be placed at the root of a "U" shaped guard. The legs of the U will help prevent solid matter from jamming directly into the orifice and aid self clearing after each stroke. I did this on the one I made and it has never clogged. I can only guess the guard is the reason.
   / Got asked to bid a very unusual project #389
Any updates on this project?
Yes! The project manager decided to have the company that removed the RR tracks remove the log jamb. Reason is because the bridge piers required divers to inspect pier footings, so it made more sense for them to do it. They utilized a floating platform with outboard motor. Couple guys on platform used a combination of saws and gaffs to get the logs moving.
Luckily I am still doing some of the tree removal on land nearby, so alls not lost.
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
Kubota M7060 4x4 Cab Tractor with Loader (A54865)
Kubota M7060 4x4...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
CAT D6C Dozer (A47477)
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
