JasperFrank
Elite Member
- Joined
- Nov 23, 2018
- Messages
- 2,942
- Tractor
- Ford 1220
Out of 20 acres, I'm just now finishing up on clearing up all tree falls and debris on the 4 acres residential part of the property. Its divided into two tax lots. The other 16 is forestry deferred, difficult to access, and prop taxes on this are $400 a year. I spent 28 years, pulling out fuel loads and mechanical thinning from this 16 ac area. Thought I had it pretty clean and proper, then we had an Ice Storm in 2021? I had to start over cleaning up this area. And had just about got done, before the 2023 ice storm. We loved using this area because we had made foot trails, and it was like owning one's own private park, which I would walk in the mornings with the dog. Its also a bit of a wildlife Island now as the surrounding neighbors have clear cut.
Yesterday, I did a deep survey of this 16 ac for the first time after this latest, and much more major ice storm. I tried to walk the prior established paths. All that prior work of many years is gone. Took three hours just to climb over everything on the old trails, which were 15 minute walk trails, some too over covered with fallen trees to pass.
I just turned 66, and I had a realization that, I'm never, going to recover and make this the same as it was in my life time, doing what I was doing before. Its too much to deal with for just one person or even a small crew to handle to do manual mechanical clearing. Its far worst then when I originally bought the property. The fuel load is just insane.
So I ask the jury, what would you do? As the cost effective solution. I really don't want to clear cut. There isn't that much access because of the terrain for heavy equipment or even places to cold stack, or slash burn. There is only one path in and out. Which seems to have been used for high lead logging in the 30's and than again in mid-70's.
