Runs rough when hot
/ Runs rough when hot #21
I’m not intimately familiar with this engine, and I know there was different valve train versions of that engine made.
That said, hardened valve seats, in general, prevent valve depression over the lifespan of an engine. It’s not a significant factor in short term temperature related valve train clearances. That’s determined by other thermal expansion factors like the metallurgical properties of the camshaft, lifters, cylinder head , push rods( if they exist), valve stems, etc..
/ Runs rough when hot #22
Make sure the distributor cap isn't cracked. A hairline crack can cause some of these synptoms. They are hard to find too.
UPDATE: After reading contributions in this forum and others, I'm thinking this may be a heat-dissipation-related problem, so I'm going to 1) clean the radiator fins with compressed air and water from the hose (from the back of the radiator); 2) drain and flush the cooling system, replace 50/50 coolant; 3) remove and test the thermostat; 4) remove the lower radiator hose & check for sediment in the bottom of the radiator. If these do not work, it's possible the radiator core may have some clogs.
UPDATE: I replaced the points and condenser, reset the timing. It's a PITA due to the distributor's location, but worth the trouble to have a good running engine. I'll do this every other year instead of every 3.5-4 years. Also since I was unable to mow due to rain, I changed the engine oil and filter, and drained/flushed the radiator, poured in some nice fresh coolant. It fired right up, and is running well (for the time being). Examining the old points, they were pitted beyond what a basic cleaning could accomplish. Thank God, not the valves! I did use some Marvel Mystery Oil, that certainly won't hurt and probably helped a bit. Thank you to all who contributed.
POSTSCRIPT: started backfiring and losing power, again. I did a compression test, #2 is much lower (45-50) than #1 (80), #3 (70), #4 (70). Spark plugs, which were worn but OK 2 weeks ago are now dark, #2 being the worst. Something else is going on here. More diagnostics to come. If anyone knows a possible solution short of removing the intake/exhaust manifold and resetting valve lash, I'm open to suggestions. I've also heard that sometimes a valve gets stuck open, but it's impossible to see the valve with the cowl and fuel tank in place. So I might remove them to check for a stuck valve as well.
/ Runs rough when hot #26
Low compression on #2 could be valves, burnt or sticking but your compression is low on all cylinders. I believe a complete R&R of your engine is in your future.
You're probably right.
/ Runs rough when hot #28
You have a Compression problem no doubt. My gas 2000 110PSI Cyl. pressure when I bought it. While you can still get it to run I would put a pressure gage on the radiator and see how high the water PSI goes, Your checking the Head and Gasket Etc. My guess is you should be around 15psi running. You going to be pulling the head and it will give you a good idea the condition it's in. Warped or cracks will show up with a high pressure so your pretty much know there is a problem. Cyl. may just need new rings?
/ Runs rough when hot #30
Look on youtube.. the secret to doing points and condensor on a Front mount Distributor is to take the whole Distributor out.
Its keyed so there is no 180degree fear when putting it back in. Look at the rotor when you takr it out face it the same way when installing.
/ Runs rough when hot #31
Hi, everyone, I've had a Ford 8n, has run well for years, I've accumulated about 150 hours on the present coil, points, plugs, condenser. I cleaned the points, set the ignition timing and tested, it was running great. After an hour of mowing, it lost power and was backfiring through the exhaust system. After it cooled down, I tested each cylinder, it was getting a strong spark, and it fired right up and ran without problem. The coil was bench tested and is within spec. I'm thinking either 1) the timing somehow changed, or 2) the coil may be breaking down from the heat of operation. I want to get some other opinions. Please feel free to opine or suggest additional tests. Thanks!
condenser and then coil,
but neither are costly.
It's not the timing, and if starts right up, it's not engine wear.
Fuel deliver? Maybe.
My money is on the ignition.
Bench testing a coil is about meaningless unless it has failed completely. But then it wouldn't start ;-)
2022 Deere 17G (A64126)
2022 Deere 17G...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
213086 (A64276)
213086 (A64276)
