Prices on driveway paving
   / Prices on driveway paving #41
Bought the place in 1980 with 500 ft. gravel drive, it's almost level. After about 15 years after garage built I had asphalt paved back then about $6,500, they paved drive and garage area total 8,000 sq.ft.
I had it repaved a year ago, drive a bit wider so 8,500 sq. ft. picture shows close to end near house. $24K. I recently had it sealcoated $6,500 what original paving cost. It's the best thing I ever did. The house floors stay clean, no gravel dust. We roll carts on it almost daily. Unless we get over a foot of snow I hand shovel...it's so easy.
   / Prices on driveway paving #42
There are several types of permeable concrete and asphalt. The most common type would be FC-5; which is what you see on the top lift of high speed roadways. You Don't want that. It doesn't hold up well to turning movements, and it has to be placed on a normal SP type asphalt, and it's expensive, and not good for handwork.
The other types of permeable asphalt typically don't hold up well to extremes in heat, so its not really used down here, I know it exists but I've never seen it.
I've seen permeable concrete, but not widely. What I've seen more in that use case, is open grid blocks, with grass or aggregate in the center 'void' of the paver blocks. This is mostly about reducing the imperiable surface area, for drainage permitting.
For more common, hot mix, asphalts; there are dozens of mix designs;
For broud capagories:
Marshall Mixes; an older type, no longer used on roads, but a bit cheaper than Super Pave, many plants no longer make this; it's cheaper, and would be fine for a driveway
S-1; uses 1/2" max sized aggregate
S-3; uses 3/8"
Super Pave; the modern common class; a good ware resistant, general purpose asphalt
SP-9.5 9.5mm rock (3/8")
SP-12.5 12.5mm rock (1/2")
SP-19 19mm rock (3/4")
SP-25 25mm rock (1") never actually seen this, but it does exist in Georgia
Friction (closed grade), a wear resistant, good traction, top lift of asphalt for roadways
FC-9.5; has additional polymer binders, that improve vehicle traction; 9.5mm rock
FC-12.5
Friction (open grade)
FC-5; this is a different material; where you specifically don't have a lot of different rock sizes, so it creates kinda a somewhat open web of rock/binder; allowing great traction, and allows water to kinda run through the voids; used on 55mph plus; where there isn't turning movements; so primarily 4 lane roads
Each of these is made in multiple traffic levels (ie ware resistance). Traffic Level-B should be a typical low speed, county/city road, and Traffic Level-C would be a state road. Traffic Level-D might be used in port loading areas/major trucking distribution centers, and other extreme environments.
Typically smaller rock will resist rutting less, but will have a nicer, smoother, ride and appearance
So, a fairly typical roadway paving;
State Road; 2.5" of Sp-12.5 and then 1.5" of FC-12.5
County Road (minor and/or low speed) 1.5" SP-12.5
County Road (major and/or high speed) 2" SP-12.5 and then 1" FC-9.5
You typically can't lay asphalt thinner than 2.5x the max aggregate size (so, 9.5mm would be min of 1"; 12.5mm would be a min. lift of 1.5"), at the same time, you wouldn't want to lay more than maybe 1.5" of 9.5mm per lift, or 2.5" of 12.5mm, but you could go to something like 3-3.5" of a 19mm mix.
There are also cold mix asphalts, that use a solvent instead of heat to keep the asphalt cement liquid/flexible, this is what you see in bags at home depot, but it is also sold by the ton at some batch plants. It's Far from ideal for anything other than patching; but I've heard of special designs being used in India/Alaska.
Recently, there is a new type of patching asphalt, called Aquaphalt; its like $80 for a 3 gal bucket; but it uses an organic polymere that is activated by water; so you can dump it straight in a water filled pot hole. So far, it seems like a better product than any existing 'cold patch'.
There has been work with 100% recycled asphalt; where they heat straight millings upto like 500 degrees F, and get them to somewhat bond. It's been used for shoulder drop offs, and other places where you don't really Need true asphalt, and it is cheaper. This is not a replacement for real asphalt, as it was milled up cause the AC (asphaltic cement) content is low, and then you burnt out more of it, super heating it.
Chip Seal; type spray a liquid AC on the base, then spread a single layer of 1/2" or 3/8" graded washed rock on the Hot AC, and then Traffic roll it (rubber tired roller). They then can add another layer or even 2 layers on top of that.
Micro Pave or Microsurfacing; (never done this, but did some reading) is very similar to chip seal; but used asphalt emulsions, with added polymers instead of straight AC.
Good comments .
Modified Marshall mix is still common in Ohio especially on low volume roads and driveways.
Micro surfacing is more of maintenance item for existing roads, very good at extending pavement life.
open graded asphalt is also used on hills to prevent freezing of surface water
   / Prices on driveway paving #43
There are designed sand/gravel mixes for soil cement that can be spread by screed type equipment or bladed equipment. It requires packing and is usually paved over.
Don’t forget that Florida asphalt will be different in design than Montana asphalt.
Pavers are no different than other coverings in that they need a proper base to sit on. Frost heaves and other such damaged small areas are an easy fix. They can be layed by machine.
   / Prices on driveway paving #44
N. TX. About 35 cubic yards (???) - roughly 18'x200'x2.5" plus some pad. Old gravel drive needed to be scraped/leveled.
Outfit that did the work seemed like a larger, local, commercial type.
$15K 2 years ago.
It could use a little crack repair and seal, quotes go from $1-4k, cost spread seems odd for a paint job.
I know nothing about it, kinda like my tractor, they both seem to work fine.
   / Prices on driveway paving #45
Did a 3" asphalt overlay on top of a older asphalt driveway in 2020. Driveway is about 600' long and 10' wide for most of it, with flare out at the road side and a 'funnel' shaped parking area maybe 50' wide at the house side. I think it ended up around 6000 sq ft, though I could be remembering wrong. No grading or other work besides the application of overlay. Cost $17k. It was a lot of money but it is a big driveway. I think the cost to remove existing pavement and pave fresh was going to be in the mid 20k range.
   / Prices on driveway paving #46
@Forest_Man this is one of the threads I mentioned. No idea if using the At system sends you a notification or who this works.
   / Prices on driveway paving #48
A crown or an inverted drive (minor V) to channel water either off the drive or channeled down the center, to where you have drainage structures. I prefer a crown, unless there is a good reason to capture the water.
On a 10feet road running parallel to a mountain, would something like this work?
   / Prices on driveway paving #49
Yes. Two or three points to think about though.
That ditch on the uphill side; if it's a long continous slope, your going to need to control water velocity, with ditch block, rip rap, disapator blocks, ect, or your channeling a huge volume, and velocity of water into a very narrow area, and will have erosion issues
The down hill side; your gonna want the area of improved road to extend beyond your wheel path, and then stabalize that with some kinda vegetation, ie seed and straw.
Depending on your landscape, topo, ect, you might need to get that water from your hillside ditch to the other side; so that means pipe (or a concrete lined swale crossing the drive). If you use pipe; go bigger and longer than you think. Dont use 4" flex pipe; I'm talking about an actual culvert. You want atleast 4-6 ft from the edge of the cross drain to the driving surface. No fun to find the edge on a rainy night with a trailer...
   / Prices on driveway paving #50
Maybe I wasn't really clear, the picture you shared is Basically correct, except that where the hill slope meets the inside of your drive, your going to need to create a dirtch/swale that keeps the water from running down your driving surface.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
