I over inflated a tire that is filled with Rim Guard in it.
   / I over inflated a tire that is filled with Rim Guard in it.
How often do you let air out? Or is it occasionally adding more air which should be easy enough (although perhaps difficult to get the exact pressure).
I bet you could sell it on Craigslist or Facebook Marketplace, although it may not be easy to fill up at home. Perhaps one could use an old pressurized paint pot to push it in.
I'd like to clean up my wheels and rims on the old Ford sometime, and probably change fluids. I occasionally get up into Washington, but rarely into north central Washington.
This the first time I have let air out, matter of fact this the first time I added air, and wouldn't you know it I added to much. 😵‍💫
I wanted to say thanks to everyone for all the suggestions and comments on the tire problem.
It sure was safer and in the end, an all-around better solution.
   / I over inflated a tire that is filled with Rim Guard in it. #33
Did you have the tractor sitting on the ground when you topped it off?
No, jacked up, tires were off the ground.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
1997 LUFKIN  48X102 FLATBED TRAILER (A58214)
1997 LUFKIN...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
(INOP) FARMALL TRACTOR (A52708)
(INOP) FARMALL...
