Kubota F series
   / Kubota F series #551
Those tiny little wheels would be ok on a smooth golf course or a manicured lawn :LOL:
Definitely Not on rough ground.
So what are you going to do?
New 3710?
You can buy mine for less than 1/2 that and have no emissions and get the same machine. ;)
   / Kubota F series #552
New 3710?
U must not like yours :D
   / Kubota F series #553
I love it, but it’s too slow.
I will use the profits for a used WAM or maybe a solid used 72” zero turn. Found a really nice Toro diesel 72”, too.
   / Kubota F series #555
Look at this beast. Makes my 72” zero turns look like toys
   / Kubota F series #556
Too slow ground speed or too slow with 72 deck ?
U just bought a new ZD1211 72
   / Kubota F series #557
Too slow because 72” F-3680 can’t go nearly as fast and the deck takes a tremendous beating rolling over the ground on 2 small tires, so you have to slow down.
Even if I was mowing a grass tennis court, the ZD would still be faster. Maybe not 2X as fast, but still considerably faster.
Yes, I know I did.
We run 2 mowers:
1. F-3680-72
2. ZD-1211-72
The ZD-1211-72 is twice as fast. I have no trouble with it on pretty steep hills, either. Just takes practice.
I think you’ll be disappointed IF speed is your most important need in the F. If it’s important, on bumpy ground, you will be driving disappointingly slow on an F.
Although the F gets better traction than a ZD, the “give back” is that it is considerably slower. Maybe your situation is that a ZD with turf tires won’t work because of traction. If that’s the case, I guess an F is your only answer since you won’t try bar tires on a ZD.
Anyway…..just trying to help you with your decision. I have a lot of hours on both types of mower. I think I’ve given you all I got for help.
   / Kubota F series #558
I don’t mow fast because some of my ground isn’t smooth.
TRACTION is the ONLY Reason I’m getting an F mower with 4wd.
I’m sold on the ZD for every aspect of my application I just can’t mow the bank if it’s the least bit damp.
It’s been 2wks since I’ve mowed it because it’s been too wet.
The F will also be a backup mower to the ZD1511 when it’s down OR I have a helper to mow with me.
   / Kubota F series #559
The 1500 & 1600 JD Front Decks has way bigger non air deck tires than the little Dinky ones on Kubota F :oops:
   / Kubota F series #560
Nuthin runs like a Deere!
Toros also seem to have bigger deck wheels.
1041 (A50459)
1041 (A50459)
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
2000 Trail King TK70SA-48.2 T/A 43 Ton Step Deck Trailer (A49461)
2000 Trail King...
Payment Terms (MUST READ) (A50775)
Payment Terms...
