I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #21
What type of tire? R4s are thicker and more robust. Maybe that's why most compact tractors come with them by default these days.
He could go to something like an 8 ply which would offer some flat protection, but not like a solid or foamed tire. Really, $500 for two to get filled is pretty good.
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #22
Maybe tweels will solve your problem.
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #24
You might try Slime in them. It seals small holes.
I have had problems with Slime after years of installation. I do better with the pink Berryman's product for that function. Sold the same places as slime with a few exceptions...TSC is the only place I have seen Slime for sale.
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #25
I bought a set of these suckers and they will kill your back.....like riding on stone wheels. It looks like that they were designed to give on impact....well your mower needs to weigh 5x or so of commercially available machines for that to "might" happen. Well my 61" 36 HP commercial mower with an upgrade (comfort) seat didn't fit the bill. Very dis-satisfatied "puker" of my money!
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #26
I'd say they come with R4's because most of the small ones are 'hobby' tractors. I know with Kubota at least, you can specify what type of tire you want but the default is R4 which not something I'd want. I've had R4's on previous tractors and the traction, especially on damp dirt is marginal at best.
I have a small Christmas tree farm and punched a lot of holes in the turf tires of my previous tractor. I opted for R4s on the new tractor and have had 3 years without a flat.
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #27
Proble we have is too many of them nasty black locust thorned trees on our property and i get a flat everytime i mow etc...Is it good to foamfill the front tires? $500 for front tires only.Any downside to foam fill?If they last 5 years it will save me money and labor. 7 16G.1W is on front tires.Suggestions please
I attended a Michelin tire seminar. Speaker said that when all else fails to find the leak put on metal valve stem covers that have seals inside. They will hold up to about 120 pounds of pressure. It cured one of the tires on my motorhome that leaked constantly even though I had replaced the core. Auto parts store for about $10.00
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #28
I watched a video a few years ago on a material called Tire Jec. I tries it in my front tires on my 485 Case IH tractor and it works geatl. Have not had a problem with my front tires since. I ran over a bottle along the highway a few years ago and it punched the tire. sound like a 22 shot and the sealer shot out for a few seconds and then stopped. I finished my mowing and when I got home I checked the pressure in the tire and it had lost 5 pounds. I ran that tire at least another year before I put news ones on. I buy the tire jet by the gallon and always pay in any new tireskeep it in my front tires. I run fluid in my rear tire so it will not work. It says on the jug that it is only good in tubeless tires but I use it in tube type and it works great.
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #29
Our dilemma here is mesquite thorns on the ranch. We have a number of wheeled vehicles on the ranch so I have had the opportunity to try many approaches to the problem over the year. Interstingly enough we have never had an issue with flat tires on our tractors (Ag Tires) other then having a mesquite stump once punching a 2" hole in a rear tire (old tires; had to replace the tires). Anyway, on all of the rest of offroad stuff (Kubota side by side; 3 ATV's-Polaris/Kawasaki) and a Bobcat we have had numerous oportunities to try out solutions. Meanwhile we do nothing special for leaks in the tractor tires (which we haven't had any other than the one I described). Perhaps it has to do with the areas we use the tractors in on the ranch vs. the other vehicles.
We got the Bobcat S-650 new in 2011 and had the tires foam filled by the dealer before it was delivered. Harsh ride but never an issue with flats. Replaced the wornout tires at about 1000 hours (we also are on very rocky soil) and currently have about 600 hours on the new set. Running with Bobcat Extreme Duty tires foam filled. Interestingly enough a few months ago I was at the Bobcat dealer and noticed all of the new wheels sitting in their yard with new tires on them. Service manager told me that it was cheaper to replace the whole tire and wheel when foam filled rather than trying to scrape off the old foam upon tire replacement. As a sidebar, I also talked to them about replacing my S-650 with a tracked equivalent; he said they still sell many more wheeled versions in this area compared to elsewhere in the country due to the rocky soil. The tracked versions seem to get their tracks torn up or torn off rapidly while working in the limestone hills. I will stick with the foam filled tires for now.
Regarding ATV's and side by sides. Of course they run low pressure tires. We have been running with Slime for years. Mixed results. Most of the thorn holes plug off with the Slime but it still takes the ocasional plug to repair a larger hole. Some of my tires have 15-20 plugs in them before they are replaced due to age and wear. Last year I got the bright idea to replace the Slime with the Flatout kevlar stuff. Of course you can't mix it with Slime so it involves dismounting the tire from the rim, washing out the rim and tire and remounting the tire and adding the 'stuff'. I spent 1-2 hours trying to get the first tire off the rim (unsuccessfully) and went to our small town's repair shop that had better equipment. The owner said he would do all of the tire dismounting, cleanout, remount and add the kevlar stuff for $15/wheel (I brought the wheels in 4 at a time already taken off the vehicles). Hard to pass on that deal.
So we have been running the Flatout stuff now about a year in 16 wheels. Results are mixed. The Flatout stuff doesn't appear to stay liquid in the tire like the slime; instead it seems to coat the tire (and rim) with a gooey mess. So depending on the size of the hole you may or may not get it sealed off. Bottom line for us is that we are still manually plugging some holes, other holes are sealing (similar to the experince we had with Slime). I'm not convinced that the Flatout type material is that much better than slime or equivalent and certainly is costlier. If I had to do it over I would have probably stuck with Slime. But YMMV.
One other thing to be aware of. One time I had to replace a tire on the UTV due to sidewall damage. Had to replace the rim. Took it to the local shop. Got it back and then had a slow leak for a long time.Went back to the shop. Turns out when they mounted the new tire they did not clean off the fiber from the Slime off the rim and I was leaking from a failed seal along the rim. CLEAN the rim where the bead sits!
Finally someone mentioned that valve stems and cores can be an issue. I second that thought. Over the years we have our share of the same problem. Cheap to replace and they do go bad over time. Consider steel stems instead of rubber in the future.
   / I have a 29hp 4 wheel drive tractor for our 20 acres and front tires are always flat #30
I've seen videos on this on YouTube. Onelonelyfarmer swears by it.
INOP/NON-RUNNING 1999 Chevrolet Express Bus, VIN # 1GBJG31R7X1137055 (A57453)
INOP/NON-RUNNING...
6ft Teakwood Indian (A57454)
6ft Teakwood...
20ft Shipping Container (A57453)
20ft Shipping...
2020 Global R3 Air Street Sweeper (A56858)
2020 Global R3 Air...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
