plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,858
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I have extensive experience in this area.I have recently had reason to start some research on getting some security cameras installed on my place. 40 acres mostly woods, house in center of property.
First, if you have no experience with surveillance cameras, prepare to be very disappointed. I'm not saying they are not worthwhile-- I have many of them deployed. But they are not anywhere close to the capacity of the human eye.
My opinion is that Reolink cameras are terrible-- with the exception of the new Reolink video doorbell. Their low light capability (after dark) is far below industry average. Many people start with them because they are cheap, but then abandon them later.
Doing cameras over a wifi signal is considered to be a poor approach. Many, including me, won't do it. I do have a wireless bridge to connect my residence and barn together, but that is a more robust method compared to a camera with a wifi signal.
I would suggest a few things. First, get some initial experience with deploying wired cameras around your residence where the internet connection is. Most people use a POE connection since the video signal and power both go through the same Cat5/Cat6 cable. That in itself has many challenges but will let you get some practical experience.
Next, depending on your terrain, consider using "trail cameras" to keep an eye on remote areas. If you need more immediate access to images, you can pay the extra $$ to have a cell-equipped trail camera.
For consumer grade cameras, I have heard the Arlo system is pretty simple and works reasonably well. But it also includes an on-going subscription cost.
You also might consider getting some quotes from local security companies. The biggest factor, in my opinion, is your lack of experience. Overcoming that would be very good. This is a venture where it is very easy to get started and start buying equipment, but also very easy for that equipment you bought to not perform well.
Finally, beware of chasing "megapixel" (MP) size with your cameras. The common models now are 8MP / 4K cameras, but the cheap consumer grade models come with a 1 / 2.8 sensor which is a mismatch. A much better performing camera would be a 4MP with 1 / 1.8 sensor. There are a lot of technical reasons for this which I would not delve into here. But fyi I recently changed one of my cameras from the 8MP model to the 4MP model for much improved night performance and less blur with motion. Even though it has "fewer pixels."
Also, if there is much distance involved, you are much better off with fewer megapixels with an optical zoom, compared to more megapixels with no zoom. Cameras with optical zoom from 2.8 to 12mm are very common. And I'd suggest you pretty much forget digital zoom-- it sounds tremendous but in reality doesn't work very well and not nearly as well as having optical zoom.
Good luck-- this can be a very fun project to pursue, but beware of the many banana peels to possibly slip on!
