New to me TC29D cranks & won’t start
/ New to me TC29D cranks & won’t start #41
My first suspicion on a diesel if it has low compression is that it has been ether tested and in doing so some rings and or piston lands have been broken. A compression test is nice to do but either prior to or after I like and prefer leakdown tests they are much more informative.
/ New to me TC29D cranks & won’t start #42
Sorry I didn't take time to read all replies but wanted to ask you.....
1. Have you checked for possibility of front seal on injector pump leaking fuel down into gear case which then drops into oil pan. Has happened to more than one person.
2. Did you change oil when you did other maintenance.......I have put multiweight HD oil into engines that had been running non detergent and have seen them act like this because sludge was loosened.
Question on that one what is a leak down test and how is it accomplished? I’m tired just give me the fish I don’t want to google haha. Have updates here to post on tractor test
1. How is this possibility of leaking injector pump determined? Do I monitor oil level on dipstick or ?? Sorry if dumb question once again it’s late I’m tired just give me the fish don’t make me google haha.
2. New tractor to me I have not yet changed engine oil
So updates to previous questions let me know if I leave anything important unanswered.
Air intake behind filter seems good no obvious signs of dirt ingestion
Compression tested
All cylinders low
pictures attached of each cylinder at test and after adding a tbsp of engine oil and re testing (all three compressions went up significantly after adding engine oil and re testing)
Front cyl 110psi before oil 180 after
Mid 160 before 250 after
Rear 195 before 250 after
/ New to me TC29D cranks & won’t start #46
A leakdown tester is connected to an engine in the same way a compression tester is and it also has an air line attached from an air compressor.
Then with the piston at top dead center of the compression stroke the valving is opened to allow pressurized air to flow into the cylinder most will have a flow meter attached so you can see how much air is blowing through the cylinder under test. By listening and feeling you can check for air coming out through the exhaust or intake which verifies your valves. If the air is escaping through the crankcase and blowing out the breather or the oil fill it's getting by the piston and rings.
Glow plugs all individually manually tested with battery charger set to 2 amps
All 3 cherry red tip after 4-5 seconds
So can I test the GP system by manually grounding a GP and connecting the lead that normally goes to the GP bar and hot wire it to the tip of GP
That way I can visually see that the system is working?
ALSO now that we’ve confirmed everyone’s suspicions of low compress do I need to move forward with fuel pressure testing or anything else besides soaking the rings with ATF for a week or two before testing compression again later??
/ New to me TC29D cranks & won’t start #48
That’s a very low compression reading.. how confident are you in the test.?? Are u taking it from the glow plug holes.??
Have u tried another compression gauge.??
U can rent them for some parts houses.. AutoZone..
/ New to me TC29D cranks & won’t start #49
Fuel pressure.?? I thought the inj. pump was gravity fed.??
The fuel went from tank to filter, then to injection pump.. let me know if I’m mistaken..
/ New to me TC29D cranks & won’t start #50
Separate the GP wire from the plugs (they're good) and turn the ign key to activate them. If they're getting power at all you can skip an electrical load test.
A 'dry' compression test (sat for a while) is expected to read low. Rings may be coked and stuck, so the long soak might help to free them up. Getting up to op temp will help too, so I suggest re-checking after each step. If one reads low, that's be the one I checked every time but wouldn't read too much into what the others will do right away, nor would I change the oil too soon if it's not dark and opaque.
This model has no fuel pump and is indeed gravity-fed. Filter quality/condition, and condensation in the line to pump come into play. BTDT so note what comes out when bleeding from inlet or lines
btw, I have the complete manual for TC29 & TC33 and can share pages by PM or email, so don't forget.
You are correct gravity fed
By fuel pressure I meant to test for high pressure fuel after injection pump
Someone mentioned that previously here in this thread
/ New to me TC29D cranks & won’t start #52
I mentioned condensation in fuel lines in a previous post. My BTDT with TCs is that there is a spill cup with a drain hose around the filler and under the hood. Tree duff can clog the drain and rain water will fill the cup above the rim of the cap.
This will by thermal expansion of air/vapor in the tank to siphon that water into the tank where it will settle as expected. I've had to thaw lines to clear them twice. (not tarped in Winter back then, Doh!) My prevention is to remove the cup (1) and/or close the hood on a rag or bag (another 1) to overlap the cup accordingly & keep detritus or water from building up in it.
Prior storage can have as much effect as prior maintenance on how quickly a long-parked tractor starts up, how well it runs, or whether it needs serious work. (o/haul. short block, etc)
btw, while my manuals are for the newer DAs the wiring is pretty much the same, as are most of the mechanicals. Did we ask what the hours are or which FEL? (7308?)
/ New to me TC29D cranks & won’t start #53
When I had water in fuel lines, at the end I did a lot of bleeding at the handiest injector so a lot of cranking. Being darn sure all water was removed would have been easier if I'd had the GPs out. It'd spin faster and be easier on the starter.
And we know if there's water anywhere in the fuel system to expect a bit of coughing and clanking until it's fully purged and we're getting fresh fuel to the injectors.
I bought the deluxe diesel test kit from harbor freight.
I’m fairly confident in test each time after adding oil the pressure increased at each cylinder by similar pressure. Pressure held until I bled to disconnect gauge
Correct pressure test from GP holes individually. Replacing each GP before moving to next cylinder
/ New to me TC29D cranks & won’t start #55
It would spin faster if u took out all the gp’s and did the test..
I don’t recall ever doing it 1 x 1..
If u wanted to do a “backyard” test of the fuel system, u can remove the steel lines from the pump and injectors, turn the lines around to where they point to the outside of the engine..
Snug them back up to the pump..
Remove the injectors from the head and hook them back up to the lines..
Spin the engine and watch to see if the injectors squirt..
WORD OF CAUTION..
DO NOT GET NEAR THE SPRAY.!!!
THE ATOMIZED FUEL WILL PENETRATE YOUR SKIN AND GIVE YOU BLOOD POISONING.!!!
Or just send it all to me..(wink)
/ New to me TC29D cranks & won’t start #56
Smell the oil from the dipstick. If it smells like diesel either that seal is leaking or it's been cranked for a long time with rings not sealing
Doubt the ring soaking is going to fix your problem. I think you'll need to pull the pistons.
Everybody will have their theory about what's going on based on their experience, but if your compression numbers are legitimate, nothing external is going to fix your problem and it is unlikely that all 3 sets of piston rings are going to be dry in such a way to give consistent poor numbers
/ New to me TC29D cranks & won’t start #57
Just to keep you on the right path.. there is no 1 seal that’s leaking..
U have a pump called a PFR pump..
Google it..
The fuel is sealed internally by metal to metal sealing surfaces..
There are orings that keep the fuel from leaking EXTERNALLY..
If u have fuel in the oil, so bad that it’s noticeable.. there’s only one major component where it can come from: the injection pump..
The injectors “can” dilute oil “IF” they’re stuck open and putting fuel into the cylinders like a water hose..
Injectors are tested with a gizmo called a POP TESTER..
They’re hooked to the tester and u pump up the pressure on its gauge until the injector “opens”.. or pops.. hence the name “pop tester”..
Each injector has to be set equally according to its specification..
/ New to me TC29D cranks & won’t start #58
Google it..
Poor man's quick and dirty pop tester (sort of) is pulling an injector, angling that injector tube out away from the engine, reattaching injector, and cranking/observing pattern. Pressure is high enough to inject through skin so obviously it needs to be pointed away from anything living.
Note this doesn't test for appropriate pressure being developed by the injection pump or if the injector is popping open at the right pressure (like a real pop tester) - however it will test if the pump is developing enough pressure to pop that specific injector and what that injector pattern looks like. Allows you to make certain there is fuel getting in the cylinders
EDIT: thepumpguys just said this exact thing in post 55 -sorry didn't see that
/ New to me TC29D cranks & won’t start #59
One other thing is if you're using ATF as a penetrant, use the type F trans fluid made for pre-computerized Ford transmissions. Much better for the application than any of the newer formulations.
Easy to see for yourself what it does to your hands versus newer fluids
/ New to me TC29D cranks & won’t start #60
With the numbers that you got from your compression test she'll never start, using the starter. If it was a geared tractor you could try a tow start but I would just about say it's teardown time. It has a slight possibility of bad or misadjusted valves. But my first guess is broken pistons or rings.
Good luck.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Truck Tractor (A61568)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2021 INTERNATIONAL CV515 4X2  S/A FLATBED TRUCK (A59906)
2021 INTERNATIONAL...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
