Midniteoyl
Super Member
- Joined
- May 20, 2013
- Messages
- 5,233
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
So, looking for a new trailer, I ran across 3 that are the exact same price but different builds.
The 3 trailers are all 20' 14k Load Trails:
20' 'I Beam' frame w/Max Ramps and Toolbox-
20' 'Standard' frame w/Max Ramps and Toolbox-
20' 'Standard' frame w/Standup Ramps and Toolbox-
And there are also 2 22' trailers w/o toolboxes that are actually a tad cheaper, both Standard Frame. One w/ Max Ramps, the other Standup.
Questions - Besides looking way cool, how useful are the full width 'Max Ramps' vs the standard Standup in real life use? I like that they fold flat giving you a full flat deck, and they can be pinned into the upright position if needed for longer loads, but how useful is this in real life use seeing as the Standup's can be removed when not needed anyways (but then need to be stored)?
And, just how nice and useful is the 'I Beam' frame in real use? I get its suppose to be 'tougher' (8" I-beam vs double 6" C-channel), but it also weighs 500lbs more and has no stake pockets but adds more D-rings and chain points to make up for it. The extra ground clearance is nice, but I wish they would have just lowered the deck instead.
And then, the 22' Standard frame trailers are ~$200 cheaper, but lose the toolbox which isn't that big of a deal. And I had originally went looking for a 22', having a max loaded length of around 20' and wanting a little 'wiggle room' for weight and balance.
So, which one would you pick? Trailer would be used mainly to move a tractor in 'ready to work' condition of ~20ft and 5600lbs, with the occasional 30min trip for a rental skidsteer/mini-ex/boom lift/etc up to ~10k lbs, along with all the other normal trailer trips like lumber runs. I can't seem to make up my mind, LOL
