Got another one, my Tach works at start up but stops working shortly there after.
   / Got another one, my Tach works at start up but stops working shortly there after. #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
My Tach stops working shortly after startup; it runs for approximately 15 to 20 minutes.
I haven't taken the Dash apart yet.
My question is, is there a quick way to get the dash out so I can check the connections ?
Thanks ahead of time.
   / Got another one, my Tach works at start up but stops working shortly there after. #2
So the tach does work and then stops. I would say your tach gauge works fine. The question is the cable and the cable end interfaces.
15 to 20mins tells me the tach works until something heats up and expands. Then the connection to drive the tach is disconnected.
Don't tear into the dash until you know where the cable end goes into the tractor. That's my first guess.
Freightliner Tender Truck - Adams Tender (A55315)
Freightliner...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
KSI Conveyor (A55301)
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
KOMATSU D51PXI-24 CRAWLER DOZER (A52707)
KOMATSU D51PXI-24...
