   / Share Pics of People Hauling or Towing Something Wrong #19,981
Mine were 14.5" , G rated, I think. That puts it somewhere around 3,000 to 3,500 lbs each tire. I can check the actual tires if you want.
However, for a set of 4 tires, that puts it in excess of 12,000 lbs.
I may try to add a third axle, so if I blow a tire, I'll still be able to tow to a safe pullout.
As mentioned, so far I've only done the aluminum boxes that are somewhere around 6K to 7K.
I do use equalizer bars.
As far as the other vehicle, those looked like 5 or 6 lug standard wheels. So, my guess is they were pushing the weight rating, although the tires didn't look flattened.
I would like a 20' or 24' steel box. Although I built my dolly/tongue to only haul 8' boxes, so if I find an 8'6" box, I'll be out of luck. But, loading and unloading a 20 footer will be different.
20' for storage from other TBN people here are these,
   / Share Pics of People Hauling or Towing Something Wrong #19,982
Surely, none of us here on TBN have ever had a wheelbarrow experience similar to this , right? :rolleyes:
At first, I thought the board broke, but I see he just slipped. If it was a wheelbarrow of manure, they could call him shlt head.
   / Share Pics of People Hauling or Towing Something Wrong #19,983
I have a cheap wheelbarrow that I put a airless tire on and use once in a while. I have my Dad's garden cart which I use a lot.
No way am I going to start my tractor to move some small items.
That guy slipping on that board with the wheelbarrow, reminds me of the time I filled a wheelbarrow full of manure and pushing it out of the barn, up the catwalk. I'm glad it was winter, almost to the end of the catwalk I slipped, but the last thing I did was push the wheelbarrow away from me and we both fell in the frozen manure. I didn't get anything on me.
   / Share Pics of People Hauling or Towing Something Wrong #19,985
Friends don't let friends own wheelbarrows.
I haven't owned one since we moved to ND in 2011.
Here is a pic of my wheelbarrow with a can of coal ash dumped in it the other night that I'll be spreading in the driveway today.
   / Share Pics of People Hauling or Towing Something Wrong #19,986
yeah, a wheelbarrow and a tractor are both tools, use the tool that makes the specific job easier. I'm not lugging a wheelbarrow across the yard and handling the load more often if the tractor fits.
   / Share Pics of People Hauling or Towing Something Wrong #19,987
When I bought my first (small) backhoe I thought about buying one of those big two wheeled wheelbarrows to drop spoils into as I was digging. Then thought "who's going to push that afterwards?"
   / Share Pics of People Hauling or Towing Something Wrong #19,988
+1 on that. I have 3 wheelbarrows, a fairly heavy duty one that was my father's, a fairly new one with a poly tub and a light duty one I found at the dump 40-odd years ago that my wife uses when gardening. All 3 get used. Tractor loader gets used for stuff larger or heavier than I want to deal with using a wheelbarrow.
   / Share Pics of People Hauling or Towing Something Wrong #19,989
The big Rubbermaid garden carts are nice, and can haul quite a bit.
One of the big things nowdays are small tracked powered wheel barrows. I haven't justified one yet, but they could be sweet for some things. The problem with hauling away dumpings from a back hoe is that one could fill one's cart mighty quickly.
I remember from gradeschool that we would fill our manure wheel barrows at the top of the hill, and head down the hill with the thing so full that one could hardly pick it up. I don't remember dumping many, but there likely were a few that never quite made it to the destination.
I picked up a used wheelbarrow that somebody put 4 wheels on. It is handy for hauling stuff where it is flat. However, it can get away from one pretty easily on a slope.
   / Share Pics of People Hauling or Towing Something Wrong #19,990
I have a wheelbarrow and 2 Gorilla carts. I do have to admit that the carts and wheelbarrow only get used for downhill or the same elevation. A couple of weeks ago I did load some wood into one of the Gorilla carts to pull up to the woodshed. I rethought that and used the tractor to pull the cart up the hill. I did not want the handle to get loose, so I used a pintle hitch. :ROFLMAO: :ROFLMAO:
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
RoGator RG1100C (A56438)
RoGator RG1100C...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
23ft x 22ft Double Garage All Metal Building (New/Unused) (A59225)
23ft x 22ft Double...
2019 CATERPILLAR 289D SKID STEER (A52709)
2019 CATERPILLAR...
