Always keep a "blank" SSQA faceplate on hand...
/ Always keep a "blank" SSQA faceplate on hand... #1
Bansil
Gold Member
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
So I grabbed a couple of these 1/4" plates for cheap (I can't buy the steel, cut it out ,bend it and weld it for the price I have paid between $95 and $119 shipped! Free to me.
So I needed to move the older chicken coop about 500 ft
I tack welded a piece of 1/4" angle iron on the front of it.
Then used a Piece of 3/16 tubing to spread the load out. A couple Ratchet straps and walla...
I will grind the tacks off and use this one today to make a custom rake.
These plates let you use the pivot point or real close, for maximum lift capacity
/ Always keep a "blank" SSQA faceplate on hand... #2
I don't see any QR's in the post.
OK, fixed it. (y)
/ Always keep a "blank" SSQA faceplate on hand... #3
I bought a 1/2" SSQA plate for $155 for a custom attachment I designed. The owner of the fabrication shop told me he could not have made it for double the price.
It fit perfectly so no complaints. Of course it came from China. Here it is loading a bulk bag of firewood.
Lol...what would they be called 🤔 I just went with Quick Release...stupid question is that qr code you posted actually one for the picture? I'm DOS/win3. Old :p
SSQA What is that?
Thanks...good thing I'm American....and have a kubota 😁
/ Always keep a "blank" SSQA faceplate on hand... #7
SSQA What is that?
Here, SSQA stands for skid steer quick attach and it signifies that type of attachment design.
/ Always keep a "blank" SSQA faceplate on hand... #8
I take It you dont own forks?
/ Always keep a "blank" SSQA faceplate on hand... #9
OP -
in your tractors listing you list a "2024 Kubota B6201".
Is that a typo?
/ Always keep a "blank" SSQA faceplate on hand... #11
Few things are more fun than making tractor attachments. Last summer I made a drag out of a 1.5" angle iron shipping crate to respread the 3/4 rock on my barn/house yard. Put some 1" skids on 4 corners and a 2x6 back stop. 1' of rock falls out under the 4 angle iron blades and the backstop pulls the excess to the next low spot. Works okay, better than a rake and more precise than back dragging a bucket.
I do but they attach to the bucket and I lose to much lifting capacity 4ft from pivot point.
/ Always keep a "blank" SSQA faceplate on hand... #16
some people don't realize loader lift capacity goes down as the height increases. his attachment can effectively lift more than pallet forks because his loader is much lower than it would be with pallet forks. assuming his attachment is the same weight as the pallet forks.
/ Always keep a "blank" SSQA faceplate on hand... #17
I like your chicken coop hefting setup.
Gotta say, though, as a clumsy operator, I'm afraid I'd drop the backhoe boom by accident, and bury myself in chicken flickings.
:unsure:.....:oops:......:ROFLMAO:
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
Grace Quick Attach Tree Puller (A66408)
Grace Quick Attach...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
