Went from a Category 1 to Category 2 tractor. Now attachments won't fit
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #31
The pin is loosened to allow the half that is threaded to spin.
The pin is re-installed. It does TWO things. First....yes it keeps it from spinning and changing the adjustment. But second....that is also how it is attached. Without that pin installed, the two halves of the stabilizer can simply come apart
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #32
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #34
I went from a cat one to a cat 2 tractor and the first thing I did was tear up a bunch of implements! Didn't help that they were bought to fit a 13hp tractor and I bought a 70hp tractor to destroy them with! I should have sold them with the tractor!
David from jax
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #35
The original poster has both pins removed and sitting on top of the PTO shield in his first photo.
I noticed that in pic but it didn't "register", just going to walk away from this discussion....
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #36
It’s funny the OP has only posted twice on his own thread :oops:
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #37
Great call on the diagram!
Still amazed that oem doesn't have more adjustments, and op could of made this just 1 page if he would of said he pulled the pins, I thought they were just pins for the attachment 😁
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #38
David from jax
I have the same issue. My green tractor is a cat 1 and my orange tractor is a cat 2. Being a cheapskate, I thought I could share implements with the two. Nope. Doesn't work well at all.
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #39
I went from a 47 HP Cat I to a 54 HP Cat II with no issues damaging implements. Don’t see how 7 add’l HP should make much difference other than the stoutness of the lower 3 pt arms. I do use adapters to reduce slop. Plus I‘m careful with my toys. 😆
   / Went from a Category 1 to Category 2 tractor. Now attachments won't fit #40
Good catch! I also noticed the tractor end wasn’t crimped like the implement end for any threading.
2009 Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
2009 Kubota...
2017 Freightliner 114SD Vactor 2100 Plus Sewer Jetter Vacuum Truck (A55852)
2017 Freightliner...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55852)
2012 Big Tex...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
