What is the fastest way to burn a pile of logs?
   / What is the fastest way to burn a pile of logs? #22
We were only able to get a burn permit because of infestation and then it was a circus with even CAL Fire helicopter and a city engine company responding
All legal and plenty of notification but still a circus... got it done and multiple agencies couldn't find any violations...
All of the tricks are pretty much off limits if going by the book.
   / What is the fastest way to burn a pile of logs? #23
An old tire in middle filled with old motor oil will really get & keep it going. Invite Gavin over for hot dogs and S'mores.
When we were burning piles of scrubby trees piled by a CAT, we got a bucket of tire shavings from a retread shop. Added used oil and diesel, and it made a great fire starter. Small scoop at a time. 5 gallons of shavings lasted for years
A diesel drip torch also helped.
Grandpa used a backpack fire fighting water sprayer filled with diesel instead, it was good at making flames, but the rubber shavings with diesel kept the fire starter burning longer
   / What is the fastest way to burn a pile of logs? #24
The air quality police suggest using only diesel to start fires. Burning tires isn’t a good plan unless you want to pay a $25,000 fine.
   / What is the fastest way to burn a pile of logs? #25
You'd think dry pine would burn like matchsticks.
   / What is the fastest way to burn a pile of logs? #26
   / What is the fastest way to burn a pile of logs? #27
well it's dry but not properly seasoned, I am sure there is still some bark on, it was on the ground and whole (not split) so it has a lot of humidity in it.
   / What is the fastest way to burn a pile of logs? #28
It probably will. But, if you've played with fire enough, it is extremely hard to get a 1 foot log to burn alone. You can hit it with a blow torch and it will turn black. You can throw it in the middle of a fire. Then once you start getting nice flames out of it, pull it out of the middle of the fire and it will quickly burn out.
And, if you're paying attention to fire seasons, nothing will be as dry in the winter/spring as you'd like.
Thus, get the pile stacked up nicely. And you'll still be struggling to get a little patch to start it and to get the fire going. And a little fire starter always helps.
Be careful and be safe.
   / What is the fastest way to burn a pile of logs? #29
Something I see on slash piles left by loggers is the piles are tarped, presumably to be more dry and easier to ignite next spring. When it is safer to burn without starting a forest fire.
   / What is the fastest way to burn a pile of logs? #30
It seems too much to burn under the constraints you have. If a burn pile gets out of control, the fines will be substantial.
Make piles as large as you can and let them rot.
2007 International 4300 (A53314)
2007 International...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2011 International DuraStar 4300 12ft Flatbed Truck (A55973)
2011 International...
SCALES & PEA (A58374)
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
