My ford 4000
/ My ford 4000 #1
masanders
Ford 4000
My hood says Ford 4000, the stamp on the block is COMM 6015J, the stamp below the battery is 960 44043. Is a diesel, not sure what I have??? Please help, want to rebuild it.
/ My ford 4000 #3
4-speed or 5-speed? Live PTO via a two-stage clutch? Pictures would help us help you.
/ My ford 4000
/ My ford 4000
Mine isn’t this tractor but look identical other than front grill
/ My ford 4000 #8
Yes, that is a early 4cylinder 4000 tractor, basically like a 861. The later 1965 4000's were 3 cylinder engines.
/ My ford 4000
Yes, that is an early 4cylinder 4000 tractor, basically like a 861. The later 1965 4000's were 3 cylinder engines.
Sounds reasonable what about the 960 stamp below the battery?
/ My ford 4000 #11
The 960 44043 is what is throwing me. The 960 would indicate that the motor came from an earlier Ford. This is what a model and serial # would look like on a 4000:
/ My ford 4000 #12
The numbers are stamped into the transmission case not the engine. The 960 is all about the transmission, which is the only part that is serialized, not the motor. At some point in its history someone put a transmission from a 960 into it. They will swap just fine, it appears to be a transmission from a 56-57 model tractor.
The COMM 6015J casting number is correct for 1964, 172 ci engine, same as I replaced the engine in my mutt 850 with years ago. The engines are NOT serialized, they only have casting numbers for identification. It is a non-sleeved engine used just before Ford switched to the 3 cylinder.
/ My ford 4000 #13
My 2000 63-64? 4 Cyl. now I have the #'s clean enough that I know what they are now.
CONN 6015G motor
2
R.side Trans.
DIF 310835
3 3F28
4Spd. with a 2 stage clutch.
Not sure of the actual Yr.
Everything works as it should. Super cool factor everybody asks about it!
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
HONDA generator (A64557)
HONDA generator...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
