Is a subcompact under 25hp enough power?
/ Is a subcompact under 25hp enough power? #1
TN8Man
Tennessee
TYM T494C, EA Root Grapple. JD445
Is a subcompact under 25hp engine enough power to maintain a under 15 acre property where the tasks are mowing w/ mid mower, finish mower, brush hogging, stump grinding, hole digging, box blade and typical loader work?
I have owned a 35hp and 50hp so I'm a little uneasy getting a under 24hp.
/ Is a subcompact under 25hp enough power? #2
I mean, itll do that stuff. Just with smaller implements.
I personally wouldn't mess around with something that small if you have more than an acre or so to mow.
Will you be willing to make more loader trips to do a job ?
Drag or 4 or 5 ft box blade VS. 6ft or bigger ?
/ Is a subcompact under 25hp enough power? #5
I have owned a 35hp and 50hp so I'm a little uneasy getting an under 24hp {subcompact} tractor.
These are pretty heavy duty tractor applications. I do not think the limited strength in the thin steel of subcompact tractors is likely to promote tractor reliability nor longevity.
BUY ENOUGH TRACTOR
/ Is a subcompact under 25hp enough power? #6
I do agree on the it can be done, but in more time than it would take for a larger tractor. Having five acres and a "compact" 26 horse tractor myself, I can admit that having a 33 horse or so, would have made some tasks quicker and provided the additional weight for completing some tasks with more ease.
I'm now leaning towards the same thoughts. I don't think I would be happy trying to do everything with a subcompact even though it can be done but with smaller implements/attachments and longer work time.
As they say ... buying a tractor can be a journey.
/ Is a subcompact under 25hp enough power? #8
I have 40 acres and with a rear finish mower cut 3 acres every 10 days or so all summer, and brushhog (48 in) a couple other acres of fields and even some trails a few times each year. AND snowblow all winter. I do it with a 26 subcompact that is now 16 yrs old. Regular maintenance, . It's light weight means no damaged lawns and can drive on septic bed. And it sips diesel fuel so cheap on pocketbook. Only disadvantage is small wheels and some traction issues on my clay. IF I were to do it again I might chose the B26 instead of BX26. But Hp no problem for all my many rear implements.
/ Is a subcompact under 25hp enough power? #9
25hp on 15 acres. There are some smaller frame 48hp units on the market that would be powerful and not too large.
Is a mid mount mower a requirement? That would be limiting. Is that to mow the lawn, or just acreage? If lawn, then, yeah, you'd need a subcompact to not destroy the lawn.
HP is nice for PTO or ground engaging work, and 25hp seems too little. Other work like box blading could benefit from weight, which you only find in a couple large frame 25hp units. But, weight while nice for some work, would be a real negative for other work. This is why I stick to a ZTR for the lawn, and a tractor for the field.
I'd feel really limited with a 25hp unit, and I only have 8 acres we "farm". But I really like to swing a 72" tiller, and soon flail.
/ Is a subcompact under 25hp enough power? #10
Yes it is. l did all that with 22 hp. Even cut, raked and baled hay. Some are uneasy about the weight effect on loader work. That's why they make weight boxes. I'd forget about a mid-mount mower. Hard to put on & off, in the way for ground clearance, blade changing is a pain unless you remove it. Ever wonder why so many are for sale on F.B. ?
I recommend a separate grass/lawn cutter: front mount or zero turn diesel and your 25 h.p. diesel will do the rest, including a sufficient pto house generator. Only 1 fuel source type. Chances are the 25 hp machine will fit in your garage.
/ Is a subcompact under 25hp enough power? #11
Also, as far as fuel economy goes... If it takes you 2x as long to do the work, are you really saving anything? I can till an acre of clay on a gallon of diesel with 48hp. I can break open 5000sqft of virgin clay sod in 12 minutes. Time has a lot of value for me, because I spend so many days away from home. For some, time is of little value.
I love mowing and tractoring... But I also have real time constraints with work and weather. So, I have a 72" ZTR, a 72" tiller, and a 12" boom sprayer for the property.
The mid mount mower is not a requirement now to replace the riding lawn mower. The only way that would work is if I could use it for all my tractor needs and I no longer think that can be done.
I'm going to continue to mow certain restricted areas with the lawnmower and the rest with a 35hp or more cab tractor.
/ Is a subcompact under 25hp enough power? #13
Echo getting a ZT over a MMM. ZT will be twice as fast and not much more costly than a MMM.
IMO the issue with going smaller is some of your current attachments may be too large. I have brush hogged with a tractor that size but not stuff like larger saplings.
I have a 40 HP tractor and looking at a TYM 2515. The issue I have is loader lift capacity as I need to lift bulk bags that weigh 1600 lbs. I fear the smaller unit will be marginal.
/ Is a subcompact under 25hp enough power? #14
I’ve previously owned a 25HP Kubota B2601. It was great for my property and did most everything I needed, however, it was too light for stump removal and heavier ground engagement work that needed to be done. I moved up to the largest frame 25HP in the Kubota brand, the L2501. This tractor has been fantastic. It has been able to perform every task the smaller B couldn’t. And, for my hills and due to my impatience and eagerness to get things done quicker, I added a Turbo which increased output by 45%. The tractor now produces 44HP and 35PTO.
I’m not advocating for you or anyone to modify their tractor but, it was certainly part of my journey.
Mike
/ Is a subcompact under 25hp enough power? #15
I've owned 25hp, 35hp, and 52hp tractors. The 25hp was fine for light duty work, but struggled with my 6' rotary cutter in tall vegetation, and the 6' cutter was too heavy for it anyway. The 35hp was somewhat better at running the 6' cutter, not ideal, but the 6' cutter does so much better with 52hp and the 52hp tractor is wayyy more stable on hillsides.
If you have a lot of area to mow, cutting width matters because your ground speed is probably effectively limited by the roughness of your fields and hills. You can only travel so fast. I tend to think 4-5mph is about the top travel speed you can put up with. At that point, the only way to speed up your cutting is to use a wider cutter which requires more HP and a larger tractor depending on the weight of the cutter. Your available time to mow is also a factor to consider.
I'd suggest that you look at how much area you have to mow and calculate how long it will take to mow it at a ground speed of no more than 5 mph with cutters that are between 4-7' and then evaluate how much HP you really need. Mowing Calcuator | How many acres can I mow in an hour
/ Is a subcompact under 25hp enough power? #16
I don't think I have seen the OP list the number of acres he will be mowing rather he just stated a total of 15 acres. If he is mowing five and the other ten are wooded/house/structures or the inverse of that they requirement may/will change.
We must know the facts as the devel is in the details.
/ Is a subcompact under 25hp enough power? #17
I’ve owned a subcompact and now own a small compact. It’s not just the horsepower it’s also the physical size, the big one being larger tires. I owned a Kubota BX and now own a JD 2025r. It’s only 2 hp more but the larger tires and frame size is nice. The end loader bucket was also small on the BX Kubota.
/ Is a subcompact under 25hp enough power? #18
I looked really hard at downsizing my tractor years ago on a 6 acre property. Liked the idea of the smaller 25HP tractor for working around the yard. I went over to my neighbor who was a lont time farmer and asked his honest opinion. He bascially said in a nice way that would not be a wise choice. He was right.
If you plan on keeping the bigger tractor and having this one as an extra, I say go for it. But if you are planning on getting rid of the big tractor to buy smaller, I think you will regret it.
/ Is a subcompact under 25hp enough power? #19
The only 'compact' on this farm is my Ford Focus RS. I don't do compact anything here, not enough balls and too light to be useful.
/ Is a subcompact under 25hp enough power? #20
My grandma runs a 25 hp JD with hydrostat with 72in deck
I run a 50HP gear drive with an 84 inch deck
She burns twice and much fuel and almost the same amount of acrage
She has to run here wide open loaded down heavy the whole time
Mines barely trying most the time
