Replacement drill press recommendations?
/ Replacement drill press recommendations? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
I have a 17" Steel City drill press. I replaced the chuck because the old one was having issues. The new one is having issues staying on as well. At this point the taper on the arbor is rather chewed up & was likely the cause of the original chuck issues. Pulley alignment has always been a bit of an issue I've been fighting. I suspect the spacing on the pullies is different so that one of the 2 belts is always getting side load & chewed up no matter how I shim stuff. Most importantly I hate changing belts, so I'm always running into issues running the wrong spindle speed for the bit I'm using or material I'm drilling. Steel City is also out of business so parts will be a bit of a pain. I may try to clean up the taper with some emery cloth, but I'm tired of fighting it. The belt issues are annoying but I can live with them, at least for now. The chuck falling off every couple holes isn't livable though.
17" has fit most of my needs size wise. I don't know what motor what Steel City has on it, but other than belt & spindle slipping issues it's had enough power. It's a 110v, so has to be under 1.5hp. I use it for some wood stuff, a lot of metal stuff, occasionally hole saws.
I've more or less decided to replace it. I want something of similar size & with a variable speed drive on it. I'd like to keep it to around $1k, but unless I luck into something used that's only the starting point for my requirements. $2k would really hurt, but is doable.
Grizzly 17" 17" Floor Variable-Speed Drill Press
Has a 2 range belt change, but the rest a variable speed Reeves drive I could probably live with. $1,000
NOVA VOYAGER DVR 18″ VARIABLE SPEED DRILL PRESS NOVA VOYAGER DVR 18" VARIABLE SPEED DRILL PRESS (SKU 58000) - NOVA, a Teknatool Brand. Uses a VFD rather than Reeves drive & has some electronics that will likely be a parts shortage later. I'm an IT guy so I am drawn to fancy electronics, but I'm worried about the gimmick factor on some of this stuff. I've heard a few reports on lacking power for bigger drills. $2k
Finding some Reeves drive 17-20" off Craigslist or Facebook marketplace. Currently not much posted, wear may be high & it might be a bit of a project to get running & rebuilt. I have enough projects at the moment, including a 2x72" belt grinder with a VFD, so while I have the skills I don't have the time & energy for a rebuild. Could get a higher quality machine though. $600-2k
3 phase motor swap & VFD a cheaper drill press. Again, another project I don't need & getting torque setup ideally may be a bit of a pain. Likely to be around the price as a Nova all said & done with $500-700+ for a decent starter machine & 400 each for a VFD & motor.
Skip the small stuff entirely & go for a Bridgeport type mill that I've been thinking about for years to get some machining capacity in the shop beyond my lathe. Unclear how convenient a mill can serve as a drill press or what I'd be overlooking. At my price point I may have some work to do on a mill. Would take a long time to source one & move it, but I have gear to move it. Maybe around $4k. Totally blows my drill press budget, but I'm looking for a milling machine at some point anyway. Maybe a new import mill like PM-940V Milling Machine – Precision Matthews Machinery Co. (which would match my PM lathe I'm happy with).
Any suggestions on what general direction to go or any specific models?
/ Replacement drill press recommendations? #2
Going through the same thing. I like the PM-940V Milling Machine – Precision Matthews Machinery Co. it is the its back ordered leave a $xx deposit that has me concerned. Keeping in mind what happened to folks that left money with everything attachments when they crashed has me concerned. I must have gotten one of there last three point grader blades. I have heard good things about them........ so I do not like throwing them under the bus. But, and I have not called precision matthews. It is way over my budget, like you i don't want another project. It is something like the above and a mag drill that should keep me out of trouble for a while.
I have not heard great thinks about grizzly as of late and my current drill press is a grizzly and its, let's say I am not happy with it.
There is this from these guys. They are close and aren't requiring a deposit and our lath came from them.
/ Replacement drill press recommendations? #3
I'd recommend a small used milling machine to use as a drill press, accurate and repeatable, durable.
/ Replacement drill press recommendations? #4
I'm still using my 50 year-old 18" Craftsman floor press that I bought new in 1974. It's showing it's age now and parts are no longer available. The quill is worn but still functions. Yeah, changing belts it a hassle sometimes but, what I really want is a crank for setting the table height. Doing it manually can get difficult.
Last year, I started looking at replacements, including the Grizzly you linked. That one appeared to be the best of the ones I looked at but I can't get over how cheaply all the new ones are made. Lots of plastic, sometimes in places where it will likely fail over time. My old Craftsman is all iron and probably weighs twice what the new ones do.
I'm still looking but for now, I'll stick with what I have until it dies.
/ Replacement drill press recommendations? #5
View attachment 858639 View attachment 858640
The taper end that is failing is not the main taper.
maybe Knock out the MT2 or 3 and then source a new one.
if you do decide to replace the press I would definitely not buy a HF 17"
I bought it and was very disappointed to find the main column was only .060 wall thickness.
The main column stand and table support were aluminum and drilling with pressure on steel would deflect the table over a 1/4" downward. I took it back and with help found an older Arboga gear head 3 phase press with power down feed, reversible 2 motor speeds and 4 geared speeds and a column that was 1/2" thick, 800lb for the whole drill press, also had an adjustable height drill head.
I added a VFD, motor is 2 HP and now have variable speed from ~30 RPM to about 1500 RPM.
All in for under $800.
Really glad i did not settle for a new china press.
Unfortunately from checking the weights of a few other new 17" presses, I am not convinced some would be any heavier built than the HF I took back.
/ Replacement drill press recommendations? #6
Very satisfied with my Nova Voyager. So easy to change speeds and wonderful for tapping.
Why don't you just rain on the parade. Looks like I won't bet getting a new drill press, lol. Didn't even think about the fact the shank went into another taper that is in good shape. I can deal with the belt alignment issues & swapping belts for now. Will probably keep an eye out for a good deal on a good used variable speed beefy press on the used market in the near term & still shoot for a mill in the longer term.
HF was never an option. Just not worth it for this class of machine, unless you are talking about a Badlands winch. I've got a Grizzly 7" x 12" bandsaw, probably a G0561 that's been ok for me. A lot better than the HF & then Frankenstein HF garage sale Jet 4.5x6 I use to use. Not that much better than some of the HF class stuff, but is decent.
/ Replacement drill press recommendations? #8
Oh Sorry, I just noticed which end you were having the problem with on the taper from the pics.
You can also get an integrated chuck / taper which could improve run out at the same time.
That was one thing I did not get with the Arboga, so I found a Shar's MT4 with a 5/8" chuck with .0026" TIR for under $60. Very pleased with it.
That looks like a nice press, that will still serve you well. I only had a small bench top press and once I decided to upgrade, there wasn't much in the way of used nice units on FB or CL, so since HF had those larger models i gave it a chance and ended up taking it back.
That thin column was a deal breaker for me. Luckily the big press showed up for $500 and
I was able to get it instead of the HF "HD" model.
ps. Funny thing is I bought a 40939 HF knee mill and it has been OK along with my HF Taiwan 12 x 24 gap bed lathe. I have had several good machines from HF and if they had put a thick stronger column and cast Iron supports I would have kept it. Rumor is HF is discontinuing the DP model I bought and the next smaller one as well.
/ Replacement drill press recommendations? #9
I replaced mine with a Baileigh. I really like it. I bought a cheap one but they have some really nice presses. Mine is variable with 5/8" chuck. I think it was around $1500 at the time.
/ Replacement drill press recommendations? #10
Get the mill. Really. And get one with the variable speed that works like a Reeves drive. I am a retired self employed machinist. Even though I have CNC machines that use VFD spindle drives I would not consider a manual machine with a VFD because the VFD drive machines are constant torque below the native motor speed and constant HP above. This means that if you are running a big drill slowly the VFD powered machine will not deliver the torque that a Reeves drive would. Also, a Bridgeport type mill is way more convenient than a drill press. I have 4 drill presses, 3 are for specialized use and 1 is just for drilling holes. Still, I use my Bridgeport mill the most for drilling holes.
Eric
/ Replacement drill press recommendations? #11
I hope you can find a good used Bridgeport mill. Others are good, too. We use our shop mill for everything. It's one of those tools that I never thought I needed until one happened along. Now I can't imagine being without. The old manual mills manual ones are fast becoming very cheap. There may yet be a few out there in tech schools, junior colleges, or old machine shops. Probably same price range as the better 18" drill presses. Be sure to get the vise, collets, drill chuck, and some bits. Hire a rigger to move it to your shop - it's worth it.
I use mine for a drill press all the time - and for wood-working as well. I just got through using it to do a project with invisible joints using glued dowls. Last year we used a flycutter to flatten one side of an ornamental hardwood slab. .
The other day a friend brought over a vintage cast part with a broken hardened bolt down inside a tapped hole. We clamped it down and center drilled that broken bolt with a tiny carbide end-cutting milling bit. A few steps later and out she came. You couldn't have done that any other way I know of.
There are times I don't even turn the motor on - just use the mill to hold something absolutely solid and dialed in to hit a true center while I turn the qull by hand. Nice tool.
rScotty
/ Replacement drill press recommendations? #12
A Bridgeport type mill has an advantage that is not obvious at first if you are not familiar with them. They are super flexible. The largest part of the machine is the column. On top of the column sits the saddle. The saddle has a dovetail machined into it and the ram fits into this dovetail. The saddle can be rotated 360 degrees. The ram can be moved back and forth in the saddle. The head bolts to the end of the ram using a complex joint. Because the ram can be moved back and forth the head can be moved closer or farther away from the column. The complex joint that affixes the head to the ram allows the head to be tilted in two axes. If you are facing the machine the head can be tilted, actually rotated, 180 degrees in either direction. The 180 degree rotation is used for shipping the machine. When rotated 180 degrees if a drill chuck was in the spindle it would be pointed straight up. Also, when facing the machine, the head can be tilted so the the spindle faces toward the column or away from the column. All these degrees of freedom allow for all sorts of complex setups. And I have certainly used all these degrees of freedom many times on my mill and mills at places I have worked. If you get a mill, and you should, get one with the variable speed head. You will not regret this decision. If you don't get the variable speed head you will curse the decision. A VFD is not a good substitute for a mechanical variable speed head. A power feed for the X axis, the long axis, is also really nice. I use mine all the time. If you do get a mill I will help you with advice on how to use it and what accessories you will need. I'm retired and would not mind at all sharing my knowledge.
Eric
P.S.
Get a mill.
A mill has been on my to do list for a while. I picked up the Precision Matthews 1340gt back in 2018. Pretty happy with the Tiawanese quality over China quality on it. A mill has been next on my list since then. A decent looking (at least on Cragslist) Bridgeport seemed to be arooun $4-5k pre-COVID here in the Denver area. Seems to be pushing $7k now. Not nearly as much heavy manufacturing here near the Rockies as back east & a lot lower supply of old mills & the like.
I know they can be had for cheaper, but I dont have the time, tools or experience for a mill restoration. I keep eyeing up a Bridgeport or a current clone as the standard for what I want. Getting a slightly smaller PM knee mill may end up being my path just to get something not worn. Getting a used private sale mill often means included tooling, which can cost as much as the mill itself.
Good to hear a mill mosty replaces a drill press. More motivation to keep the curren DP limping along & save up for the mill.
Been watching This Old Tony, Blondie Hacks, Abom, CEE Australia & a pile of other machining channels for a while. So have a decent clue about the gear & skills, but little to no hands on experience on a mill.
2006 Freightliner Auger Truck (A63118)
2006 Freightliner...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
New Holland TC21 (A62177)
New Holland TC21...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Chandler 9PT-FT High Clearance Fertilizer Spreader (A64047)
Chandler 9PT-FT...
