Fermec 650 3-point not raising
/ Fermec 650 3-point not raising #1
cpt9503
1998 Fermec 650
Greeting all,
Just joined and I'm hoping to get some help or at least pointed in the right direction. I have a 1998 Fermec 650 and the 3-point hitch is not raising. I had the hydraulic lift piston replaced and still not raising. Ideally I would like to be able to track down a service/repair manual and if not maybe someone can direct me on how to test the pump or other suggestions.
Thanks
Mark
/ Fermec 650 3-point not raising #2
As I understand it the Fermec line was formed partially on Massey backhoe and skid steer lines. That would lead me to believe the three point could well be mostly based on what Massey used in so many of their tractors for years. If you can confirm that with some photos of the lift portion and any evidence of that maybe someone can offer some ideas. Many people are familiar with the "Ferguson system".
/ Fermec 650 3-point not raising #3
I believe it was a Massey 50H before being rebranded as a Fermec. Parts get very interesting sometimes as the crossover is blurry.
Thanks for the reply. I'll get some photos and post them. If I remember correctly the hydraulic lift piston I replaced was also used in a Massey.
Thank you. Very helpful. I'll do some research and see what I can come up with.
/ Fermec 650 3-point not raising #6
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2012 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2012 Ford F-150...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
