No second gear
/ No second gear #1
Adventuris
Tym
Was using my yt359c today and second gear stopped working , first and third still work fine anyone have any ideas
/ No second gear #2
Since your YT359C is a newer model, this definitely comes under the Yanmar powertrain 10yr warranty!
/ No second gear #3
I would begin with the range position switch. To check it turn the key off, hold the display button and turn the key back on. A screen will appear that says "Checker", release the display button. Press and hold the display button again. The next screen will appear saying "Switch, Meter, T/M", press and release the display button to toggle over to "T/M". Once there, you should be able to test the range position sensors. If the voltage doesn't change between shifts, you may need a new switch. Most likely a warranty issue.
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
