Diesel mixed with gas
   / Diesel mixed with gas #21
   / Diesel mixed with gas #22
I wouldn’t throw that ratio of gas on a burn pile. Pouring half of the mix into a gasoline vehicle wouldn’t hurt anything. Or if you have waste oil disposal just pour it in that.
What's wrong with that ratio? Better to put it to use than throw it away.
   / Diesel mixed with gas #23
Its 37% of the vehicles that there tanks were filled with it
don't work!
1973 I do believe was the year polution crap was installed
on half ton not the three quarter
I don't believe we will ever see the company that was going to
make regular gas from lp will ever be in production!
willy
   / Diesel mixed with gas #24
Gas is too volatile to safely be used to start fires. It can be done sure but as a general suggestion putting gas on fires isn’t a good idea. Just 1 gallon of diesel in a 7.5 gallon mix won’t be enough to change the volatility. I wouldn’t have any hesitation to add that mix in my gas vehicle with a 40 gallon tank. I was being even more cautious when I suggested just adding half of it at a time.
   / Diesel mixed with gas #25
Whatever you say. We've used straight gas for forestry burns for as long as I can remember.
   / Diesel mixed with gas #26
Not worth risk using except to start burning pile.
   / Diesel mixed with gas #27
Dad and I ran out of gas on a farm truck when I was kid about 15 miles from a station in the middle of a field. We had some diesel so dad poured about a gallon in the tank. He started the truck and played with the ignition timing till it ran half decent.
We drove it to the station and topped off with gas, set the timing and that was that. I would not hesitate to burn it in an older vehicle.
   / Diesel mixed with gas #28
makes good fire starter for brush piles
   / Diesel mixed with gas #29
All of you are wrong.
I’d use it as a starter for burning brush piles.
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
2013 CHRYSLER 300 Sedan (A56859)
2013 CHRYSLER 300...
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
New/Unused AGT Industrial MX-MRW14 Mini Tired Skid Steer (A57453)
New/Unused AGT...
BOMAG BW213 SMOOTH DRUM ROLLER (A58216)
BOMAG BW213 SMOOTH...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
