Mower has low power after tune-up
/ Mower has low power after tune-up #1
mjw357
The Sticks, Ohio
Kubota B3200
I have an Exmark zero-turn with Kawasaki FX801V engine. Brought it in the garage last fall, all was running perfectly. This winter I changed the oil and filter, fuel filter and the rocker cover gaskets because they were leaking a bit. While I had those off I figured I would check/set the valve clearance.
Went to mow this afternoon, started right up and let warm for a couple minutes before I started.
Wheeled over to the yard, half throttle, turned on PTO to start blades, full throttle. Seemed OK for a few seconds then lost power when I started moving. It just is not making full power/RPM’s with mower engaged.
What’s everyones first thought?
/ Mower has low power after tune-up #2
Valve lash not correct. Getting too tight as temp oncreases. Just a guess...
/ Mower has low power after tune-up #3
Good guess. All the vertical V twins, Kowalski, Kohler and Briggs are all touchy with valve adjustments and they have to be right on or they run like crap.
  • Good Post
Reactions: D&D
So got it back running. Here’s what happened.
Apparently did not fully tighten locknut on one of the rocker adjusters. No damage, all parts found. Set valve clearance to 0.004”-0.005”, reassembled and ran.
Mowed for a couple minutes then died, like turning the key off. Restarted using choke even though it was warm. Surged and died a couple more times under load. Ran it back to garage with mower off surging the whole way. Took carburetor off and opened float bowl.
Debris in opening opposite needle valve. Cleaned carb out and reassembled. Wife mowed with it for over an hour, all good.
2014 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
Caterpillar 320 (A60462)
Caterpillar 320...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
