My beloved Duramax needs help.
/ My beloved Duramax needs help.
Yes I'm aware of the dreaded cp4 pump issues. however my issues started after I stubbornly asked them to replace fuel filter which was due for service but running great beforehand, when the belt,idlers, and tensioner was replaced so it makes me think it's something with the fuel filter hopefully. I'm aware of several aftermarket fixes to prolong the life of the cp4. One even mitigates damage to injectors if the pump grenades so a several thousand dollar job, doesn't cost 10k. I'm not for taking it in to get fixed, certainly not over 500 miles away.
/ My beloved Duramax needs help. #12
Trifecta - Bad fuel, fuel filter woes, injector pump failure
Everything is computerized and you need the dealer. I don't miss my Duramax, especially out of warranty issues
The smart money says if you are going to own a late model diesel pick up, buy it new and get rid of it before the warranty is out. Or buy old ones that have positive pressure to the high pressure fuel pump. All Duramax equipped pick ups prior to 2017 model year have no supply pump and the high pressure pump has to draw fuel from the tank, which puts the system under a negative pressure from the fuel tank to the inlet of the high pressure pump.
/ My beloved Duramax needs help. #13
Wonder why CP-3’s don’t self destruct under negative fuel pressures.
/ My beloved Duramax needs help. #14
If you saw the internal parts of the two different pumps, you would no why, the 3 cylinder CP-3 is very tough. The 2 cylinder CP-4 has little piss ant rollers that are approximately 0.375" in diameter that run against a two lobe cam, the wear starts very early in life for those pumps, hence the statement "they start grinding themselves up from the first time you start them".
/ My beloved Duramax needs help. #15
Why in the world would anyone build a newer pump that goes backwards in reliability?
In my pessimistic worst case scenario feel the system wasn't bled properly at least to the filter so if the cp4 pump is failing I'm imagining the hard starting issues initially were caused by sucking air there by further or ultimately damaging an already weak high pressure cp4 pump. This is getting out of my wheelhouse as im only somewhat capable of successfully diagnosing and repairing smaller old yanmar and universal auxiliary diesel sailboat engines occasionally a 40 yr old Kubota tractor but rarely have to.
/ My beloved Duramax needs help. #18
Yeah, but Bosch?
Pretty good company.
Kind of makes you wonder if the CP4 is up to the task with lots of input pressure?
/ My beloved Duramax needs help. #19
Don’t go “worst case scenario” on us. Just try the cheap things first. 9 out of 10 times, thats the issue.
/ My beloved Duramax needs help. #20
Im going with the improperly installed fuel filter, and there is air in the lines or pump.
Like Hay Dude says (its the cheap little things) that need to be tended to first.
2008 TOYOTA Camry Solara Convertible (A59231)
2008 TOYOTA Camry...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
2022 Kubota M5-111 (A60462)
2022 Kubota M5-111...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
