Wrench for removing Kubota water separator
   / Wrench for removing Kubota water separator #1
BufordBoone
Tuscaloosa, Al
Kubota L5740 & M7060
2018 M7060 - In replacing the fuel filter and cleaning the water separator, I noticed things are "tight". Not a lot of room to move around. I was able to get the (spin on) fuel filter changed by using a standard "Band" filter wrench.
I was unable to get the water separator unscrewed. Couldn't get a purchase on it.
I tried a pair of channel locks but was afraid I'd damage the plastic.
Any suggestions for the proper wrench to purchase to get that separator body unscrewed?
Also, although the std. filter wrench worked on the fuel filter, any better recommendations?
Thanks.
   / Wrench for removing Kubota water separator #2
I've always used channel locks or a strap type wrench with a soft rubber strap. A chain wrench is also a good choice to try.
The plastic bowl on my aftermarket sediment filter comes off easy enough with the rubber strap wrench stretched tight, and a hard rap.
   / Wrench for removing Kubota water separator #4
I use this one:
I line it with friction tape to better grip the plastic and minimize the chance of damage.
Depending on the model, this one may also fit:
I use this one:
Thanks. I have similar but the area is too tight for it with all the hoses, etc. from the loader.
Just a very tight area.
I'll look at the above recommendations and something will work out.
Thanks, to all that have given suggestions. I love this place.
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
