Good morning!!!!
   / Good morning!!!! #187,281
How many shanks on that 10 footer?
On our chisel it's about 50/50 left and right points. When you sink it in the ground and watch how the soil is left will let you know were the points should be.
A 10 footer are you running 2 or 3 rows of shanks?
This is either a 12 or 14 ft, hard ground a 17 couldn't pull it. Good luck
love seeing equipment in action.
   / Good morning!!!! #187,282
Got the church work done, can't believe almost 1 pm already. time flies when you sleep in..
still sunny and windy, 45 deg and pellet stove still humming along.
   / Good morning!!!! #187,283
64°F and .53 inches rain. Forecast continues.
Another good soup day yesterday. A very meaty ham bone transitioned from freezer occupant to hot star via high pressure session in Insta Pot. Joined by close veggie friends whose identity was smoothed by encounter with immersion stick. Delicious
Town today for a couple errands and Happy Hour.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #187,286
Beautiful spring weather. 64º and sunny today. Will trim up tall grasses and weeds along fences and trees where the tractor left a little growth from yesterdays mowing. Bestco flail did a good job as long as I kept the rpms up and the speed down. Love the HST for mowing.
Maybe spray some weeds around the barn and in the gravel driveway today. Waiting for the neighbors field to dry out before mowing. That property has some muddy bottom sections. Ugh.
I need to mow it before the invasive Mustard weed goes to seed, so the best plan would be to cut each time they flower before they can mature to seed. 2 -3 times annually.
Too many projects - don't know where to turn next. It's all good though. lol
Hope you all have
   / Good morning!!!! #187,288
I dropped the bomb on my manager this morning. He is tickled pink as is the foreman I work for. Pending a favourable license medical at the end of March, I AM going northwest this summer. I just cannot turn down $10,000.oo/month clear money.
Sounds like win win for everyone 🤞 cross for the medical.
   / Good morning!!!! #187,289
Sure could use some of your weather on this side...hint..hint. ;)
   / Good morning!!!! #187,290
Took off the plow off and cut some 6x6 pieces to block it up on. Protected the hydraulic ends with zip lock bags and tape. It is now more likely to snow enough to where it needs go back on??
Cleaned out the machine shed for clay and dirt tracked in by the tractors. Amazing how much dirt that accumulates over time.
Mounted back the bucket and hooked up the thumb and hydraulics. Do not have the fancy connect option so have to do it the old fashion way with brute force from an Irwin clamp.
Cat GP25 Warehouse Forklift (A57148)
Cat GP25 Warehouse...
SDLL60 Loader (A55272)
Mini Plate (A57149)
Mini Plate (A57149)
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
SKLP Pipe Banding Machine (A57149)
SKLP Pipe Banding...
