Oil filter cover plates?
/ Oil filter cover plates? #1
jjeff
Super Member
MI
kubota l2850, kubota l4150
Last few years noticed some oil filter cover plates have rectangular openings vs circular, for both engines and hydrostatic drives. The filters are the same size. I believe the relief spring, bypass valve, threads, similar media etc are the same. To put my mind at ease, if original filters used circular inlets on the cover plates and new aftermarket ones are using rectangular inlets Im I losing sleep over nothing? Several times now I've returned the latter and opted for sometimes hard to find OEM ones only because the cover plate ere different. Most of my stuff is pmd pretty regularly and I definitely like the convenience of getting filters at different locations.
/ Oil filter cover plates? #2
Smoke a little smoke drink a little drink 😉🚜
/ Oil filter cover plates? #3
Means nothing. broached holes in a filter boss can be any shape so long as the fluid can pass through unimpeded. Candidly, I've never gave that a thought and never looked either. I have more important things to be concerned with.
Yep probably losing sleep over nothing 😂. However with the price of commercial hydros and even somewhat commercial 4 strokes it's reassuring to get other input from more knowledgeable folks.
/ Oil filter cover plates? #5
I'd lean toward the ones with the round holes just because it looks smoother and more finished. But I'm a bit of a craftsman and tend to favor things where I can see that the manufacturer put a little more effort into the product.
Does a little more pride in what they build make it work better? I couldn't say that for any one thing, but a lifetime of experience has taught me that good appearances are more likely to be indicate good function than the other way around.
One thing I never have been able to figure out is why would anyone use something other than OEM filters - although I do believe that adding a bypass filter has advantages.
rScotty
rScotty
Guilty in some cases, OEM tuff torque hydrostatic drive filters at a dealership are a rip off when there asking 40 bucks a filter. Online or elsewhere are 10-20. When most of your stuff is old but I still try to maintain it Id rather spend the money on other things. Especially if a off brand filters going to work, on older equipment and probably not going to shorten the life of already high hour equipment. Not to mention I've grown to appreciate oil filters with a nut on the end of the housing most k&n filters do that especially handy with hard to reach places an oil filter wrench or piercing it with a screwdriver just doesn't work very good.
/ Oil filter cover plates? #7
My problem with the OEM vs aftermarket is that I just do not know why the one is more expensive than the other. If they are the same, why not close to the same price?
I didn't know that any oil filters came with a nut on the end of the housing. I wish they all did. The Kubota filters on the M59 are almost inaccessible to anything with enough torque to turn them.
That's nice to keep them protected, but last time I did them it took way too much innovation coupled with a 4 foot cheater just to get the old one off. And what happens if you crush it?
If any manufacturer wanted to get people to buy their overpriced OEM oil filters, the surest way to do so would be to put a something to grap onto the top. A big old nut would be great. The flats that they are now stamping into the end of the cannister just don't offer enough grab.
Of course the real solution is to move the filters somewhere convenient.
Mr Manufacturer: That hydraulic is a pressurized system. It doesn't care where the filters are. They could anywhere. How about putting them somewhere accessible? I bet you'd sell more.
rScotty
/ Oil filter cover plates? #8
more accessible is convenient, but being more accessible could make it more vulnerable to damage in field conditions, esp since it seems most forum members have lower profile sub compacts, regards
/ Oil filter cover plates? #9
Hydraulic filters work the same no matter where they are. They could be in the motor compartment, or on a rack behind the seat. I see no reason to put them under the tractor where they are both vulnerable and hard to service.
Slightly added cost and more failure points? I wish all engineers and architects were required to fix cars and build homes as part of there career training 😂.
/ Oil filter cover plates? #11
I suspect the locations have more to do with production machining of the castings than anything else.
On my M's, they are underneath but high enough not to be susceptible to any damage.
/ Oil filter cover plates? #12
Bet it would be cost, not failure.
I understand that actually knowing how to work a trade to be a requirement for engineers and architects in some European countries.
It was never a requirement in the US that I ever heard of. But still, the better engineers and architects that I know all did exactly that - every one of the good ones took jobs fixing and building either before going to school or after.
I bet it is no different now. The best ones understand the importance.
The old way of working while going to school seems a thing of the past.
rScotty
/ Oil filter cover plates? #13
good point. on vintage tractors, not sure there were any hyd/transmission filters?
my MF T035 did not. could be current tractors don't have them exposed on the upper level is for cosmetic reasons. glad i operate my M series w/plenty of clearance of access & potential damage to the thin filter housing
on my TO35, i really liked the heavy duty engine oil filter cartridge housings.
what is the gauge of spin on filters, 1/16" if that? little margin for error, regards
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2001 Ford F-450 Super Duty Flatbed  7.3L Power Stroke Diesel (A63688)
2001 Ford F-450...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2025 Unused...
