Post your Branson at work. Picture thread
/ Post your Branson at work. Picture thread #221
I bought a new grapple just mounted it on today
Then I got carried away and mounted it on the Toyota!!🤣🤣🤣
/ Post your Branson at work. Picture thread #223
Bought it from Stephens Equipment in PA.
Name brand ???? the tags fell off ....
/ Post your Branson at work. Picture thread #224
I was digging in an area that will someday be a small pond / water feature near the uphill garden when I heard a very loud squeak and I realized I hadn't checked my right front tire which is somewhat prone to air loss in a while, and sure enough the squeak was the tire dumping what air was left in it as it pushed by a large rock with a full bucket.
While it was filling, I looked around the tractor and noticed I'm missing a bolt on the backhoe - another spot I knew from the past that it should be checked occasionally as I saw the bolt there loose once... bleah
/ Post your Branson at work. Picture thread #225
I found a file I had downloaded before, called "ANSUNG PART BOOK (ALL MODELS).pdf"
Looks like I need 5, 6, & 7.
/ Post your Branson at work. Picture thread #226
I picked up a grade 8, ¾"x2½" bolt/split washer/nut at my local hardware store.
Do you think the ~5% size difference between M20 (~20mm) and ¾" (~19.05mm) is ok or should I replace with a proper M20?
/ Post your Branson at work. Picture thread #227
I would use 3/4 if I could not find a M20 and not worry about it.
/ Post your Branson at work. Picture thread #232
Hauling off a bucket of concrete the builder buried under 2" of soil when they poured the garage pad... And refilled the hole, tamped down, and seeded. I love having tools for the job
/ Post your Branson at work. Picture thread #234
That is a nice subframe. I have one. How in the world did that bolt come loose?
Your guess is as good as mine. With the backhoe hanging off the end of it though, there's definitely flex in the subframe out there, and where there's flex there's potential for a bit of movement and thus a bit of loosening, and it happened. As I mentioned, either that bolt or the one across from it had come loose previously (a few years back) and I cranked it down tight but apparently it wasn't enough. Now it's got a nyloc and the split ring, and hopefully I'll check it a little more often. I have a backup bolt/washer/nut in case I lose another somehow; if I see any loosening again I'll through locktite at it too.
/ Post your Branson at work. Picture thread #236
2022 EZ-GO ELITE...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2025 Electric Cart (A64557)
2025 Electric Cart...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
2005 Dodge Ram Crew Cab Pickup Truck (A64556)
2005 Dodge Ram...
