CS2220 with SL2420 Loader
/ CS2220 with SL2420 Loader #1
confederatemule
Am I the only person who has a problem with the loader and bucket assembly being sloppy? It seems to have a lot of slack in every pivot area.
When I back drag with the bucket is when I notice it the most.
There seems to be a lot of slack where the loader arms connect to the loader frame that attaches to the tractor.
I have 40 hours on the tractor at this time. My plan is to ask the dealer about this when I take it in for the 50 hour service. I am sure they will tell me "that is how it is made. We can't do anything about it". That is what they have told me about the other things I have asked them about.
If anyone has had a similar problem please tell me what you may have done to correct it.
Mule
/ CS2220 with SL2420 Loader #4
Mine has certainly had build issues, but cannot say I have noticed FEL sloppiness.
The only FEL issues I have noticed are:
1) the control arm valves needed lubrication to smooth out the control movements.
2) as I use pallet forks mostly there is a drop at the tips over time when I am in a long-hold position. With a bucket you would not notice the tilt drop, but at the end of the long forks you do.
I regularly reach max lift capacity on the FEL pallet forks and have added rear weights to attain stability using 90+% of FEL lift capacity. If there was sloppiness in the FEL system I would have noticed it by now.
As much as I would like it to be so, the world is not perfect, but since working out the bugs, so far, it is 'within tolerance' - as I have adjusted the computer programming atop my shoulders to account for the variations from perfection.
My attempts at DIY AI?
2023 CS2220 with 145hours to date
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
MAC FLAMELESS HEATER (INOPERABLE) (A68842)
MAC FLAMELESS...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
Yamaha 115hp 4-Stroke Outboard Boat Motor (A66738)
Yamaha 115hp...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
