Same 1000-6w fuel pump removal
/ Same 1000-6w fuel pump removal #1
Low tech Redneck
Same Silver 130
I have a Same 1000-6w engine with all of the fuel pumps stuck in the shutdown position.The pumps can’t be removed in this position due to the fuel racks hitting the casting.Does anyone know a solution?
/ Same 1000-6w fuel pump removal #2
Welcome to TBN!
Unstick the pumps with PB Blaster or similar. Tap the the rack until it is in position to remove pumps. Do you have any other choice?
/ Same 1000-6w fuel pump removal #3
I have same the problem. 3 pumps are stuck in shut down and can't remove. Did you figure out a solution?
