3/4” or 1” cordless impacts
   / 3/4” or 1” cordless impacts #11
I have a Harbor Freight Earthquake 3/4". It did OK for a few things I needed it for.
Since then they have a Hercules 3/4" model which is rated as slightly more powerful. I have several Hercules tools, and probably would choose that one instead.
I don't tend to do a lot of large impacting.
   / 3/4” or 1” cordless impacts #13
That's because they have larger anvils and produce higher torque. Beats the $900+ Mularkey. Besides, I already had the batteries. Hands down, better there too. ;)
The facts don't support the higher (measured) torque argument, all brands marketing lies about it, but I fully understand the battery issue, I'm tied into a lesser brand myself. Started 25+ years ago when that's what I could afford and just stuck with it.
Dewalt is definitely the upper tier though, good tools, just not the be all, end all in everything.
Would like to avoid another group of cordless tools, chargers & batteries.
Can’t understand why Milwaukee is the only one of the large, well known brands to offer a big 3/4“-1” impact, though.
   / 3/4” or 1” cordless impacts #15
I have the 18V Brushless MAKITA 3/4" Impact Wrench for two main reasons:
1. I have other Makita tools so plenty of batteries and chargers.
2. The Makita is (was at the time) the only one with an anti-vibe rubberised mount between the handle and the battery connection.
Apparently that protects the electronics in the handle from vibration shock.
If you rock/twist the battery you can observe the movement possible.
Nothing has defeated it yet in my work.
It has the C-ring on the nose of the anvil to hold sockets 'on' and has a hole for the optional safety pin which is secured with the rubber O-ring if you purchase one.
A colleague has the Hitachi/Hikoki 3/4" which seems OK too.
   / 3/4” or 1” cordless impacts #16
Unless you own something bigger, like a tractor or heavy equipment you don’t need a larger impact like 3/4 drive or 1” drive so the market is smaller. I own a 3/4 drive ratchet set in metric and english but don’t use it that often.
   / 3/4” or 1” cordless impacts #17
The biggest drawback on milwaukee is the battery gets loose with time where it slides onto the impact and sometimes it wouldn't connect. Always happens when you are in a awkward position to. Aside from that we love our milwaukee tools.
   / 3/4” or 1” cordless impacts #18
Would you consider something entirely different?
I was so impressed with the 3/4-inch Stanley hydraulic impact that came with my crane that I bought a used 1-inch version on eBay.
Normally I use my Milwaukee 1/2 inchers, and love them, but when up to 2,500 ft.lbs. is needed the hydraulic ones sure do the job.
   / 3/4” or 1” cordless impacts #19
My dewalt 1/2” battery impact is out for delivery today. Cant wait.
   / 3/4” or 1” cordless impacts #20
I have a Milwaukee V28 kit with 2 batteries in a canvas tote bag high up in my shop shelving unit. Ihave not used it since i got the dewalt 20V units. That V28 can wear you out quickly. Very heavy unit.
plus the dang batteries are now over $180 each.
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
1990 35 Ton Phelan Low Boy (A57453)
1990 35 Ton Phelan...
John Deere 204L (A56436)
John Deere 204L...
1999 CHEVROLET C7500 UTILITY TRUCK (A59575)
1999 CHEVROLET...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
