PTO inop (Now fixed) - Kioti DK5310SE HST Cab.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #21
Oh? What is the Oreilly part number? I am looking at using the existing beacon light wiring for adding side working lights. I just need a switch and the relay that plugs into the fuse block under the hood.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #22
Congrats AirOpsMgr, now you've had a guided tour in how to "Become a shade tree mechanic", just like the rest of us!😁
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #23
Not just as easy to order;
Kioti Beacon lamp kit DKA149 (~$40) The beacon kit provided the relay, wiring harnesses (one for main harness to switch, one for light) and switch.
The Dk has the same plug and mount on both rear sides so I sourced a new plug 7222-1424-40 - Yazaki | SWP-2P - Corsa Technic | 2-Way Kit for the other side (beacon kit had one on the light harness.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #24
Thanks, I really appreciate you trying to walk me through this, but I'll be honest, you're kinda speaking Greek to me, but I'll do my best to try and follow along, I swear!! 😆 .... (I've got very little experience with wiring unless household and even less experience using a meter).
That said, this is the meter I have & honestly don't know where to start.... (sorry, I'm that inept when it comes to this stuff).
For most of your tractor, auto, home stuff move the red lead to the red hole marked vΩ
So looking at the wiring diagram, it appears the beacon relay is different than the PTO relay, but here is the PTO relay part number from O'reilly:
RY1522
Pics of the relays for both:
Good info, I'm thinking of doing the same to add side work lights after seeing the beacon harness connector when I was looking at the PTO wiring harness.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #27
Thanks for the relay part number @AirOpsMgr !
I thought the beacon kit was much more expensive (I didn't know there was a version of the kit that doesn't come with the bracket). I will probably just purchase this kit from my dealer if he is not much more expensive than Ebay.
Thanks @D&D .
I will also get a few spare relays from the auto parts store - I think that is a good idea also.
While on this topic, I asked a dealer at the world ag expo yesterday, if it was common to have problems with the connectors to the relays in the roof of the cab for the stereo. He didn't think so, but as a suggestion, he said his crew tended to use dielectric grease on connectors that could be a problem.
I already wired directly from the radio to the speakers, so I don't have the problem anymore, but I don't have use of the Aux port and that amplifier anymore either. That is ok for me because I changed to a bluetooth radio.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #30
I just ordered it through my dealer. It was a couple dollars less if I dream up a good excuse to go to Bakersfield. If I have it shipped to me it will probably be about the same as fleabay.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #31
i just replaced the existing halogen with led. didnt have to change any wiring
I did that with my headlights and the front and rear work lights using Auxito LEDs and it worked well, but wanting side lights to provide more light coverage.
Even with the LED bulb swaps, I'm still considering replacing the overhead work lights with flood Pods down the road, the stock reflectors in the work lights create more of a spot pattern than a flood.
I have some Rigid D-SS pro flood lights on my UTV, one of those is brighter and a wider flood pattern than both of the OEM work lights combined (with LED bulbs installed); Not sure I need that much light though, lol
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #33
Hi all, wondering if anyone could help me diagnose an issue with the PTO not engaging on a 2023 Kioti DK5310SE HST cab model (150 ish hours).
I've read some posts on TBN and other sites to try to self-diagnose, but no luck so far.
What I know:
• When engaging the PTO yellow push-switch, the PTO does not engage and no light on the dash indicating PTO running.
• With tractor off and PTO switch on, tractor will not start, with PTO switch off, Tractor will start.
• Disassembled the fender mounted PTO switch housing just to check if there was a wiring issue, but since the tractor won't start with the PTO switch in the on position, I think I'm safe assuming the issue is not with the switch.
• Checked fuse in the fuse block, PTO is one of the larger square type, outter cover comes off, not sure how to remove it / test it.
• Checked Hyd fill level, it's full
• Tried raising and lowering the 3 point multiple times, no joy.
• Reading online posts with similar issues, I see multiple threads about checking a relay on the firewall, but I don't have the same relays I see mentioned - the only relays I see on mine are located to the left side of the fuse panel and just 2 of them, one above the other, none center-mounted.
And lastly, yes, it's still under warranty, but the dealer is over an hour and 20 mins away and each time I've taken it back for warranty work, it's there for at least 2.5 - 3 weeks before they get to it (always citing some issue with a mechanic being off or short staffed, etc).
I'm at the point that I'd rather pay a mobile repair person to fix it than to have it sit at the dealer since I intentionally took all next week off from travel to work at home and get caught up on tractor work, but before I get to that point, can anyone advise exactly where the PTO relay / solenoid are located so I can try to fix it myself first?
If my last resort is to call a mobile tech, can anyone also advise what the max I should be paying for such a diagnosis (just so I know what I should expect & not get snuckered).
Thanks all!
Brgds,
Greg
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #34
Had similar issue on my Ds45, found out that the back of my foot had rubbed against the speed selector lever and turned it all the way to slow. When I repositioned the lever to midway - low and behold the pto started functioning, easy fix for me - best of luck to you.
  • Good Post
Reactions: D&D
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #35
My mobile tech is $125 an hour with a 2 hour minimum, port to port, in Oregon, he can do anything, has a great rig and all the tools!
Thanks guys & good info; tracked down the issue to a bad relay for the PTO circuit.
The only mobile tech I could find was a week out, $200 for trip fee & $95/hr, so I'm glad I was able to find the issue on my own.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #38
What I know:
Thanks all!
Brgds,
Greg
the no start when PTO switch is on is correct,but that is a seperate mode in the PTO switch, I would check the switch with a test light to see if you have power going in & power coming out when switch is on
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #39
I had the same problem awhile back. Ran inside to visit with my grandson. Came back to tractor and the tractor would not lift the mowing deck. Ran it in reverse and parked the tractor. Next day I checked the tractors fluids. Someone had come by with one of those oil manual fluid extractor and removed all my transmission fluids. I had a 5 gallon container. Filled tractor and it worked again. You might want to check your fluids. Plug should be under seat.
/ PTO inop (Now fixed) - Kioti DK5310SE HST Cab. #40
That’s a first for me!
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2018 Trail King Lowboy (A61307)
2018 Trail King...
1611 (A57192)
1611 (A57192)
2016 Nissan Sentra Passenger Car, VIN # 3N1AB7AP6GY307338 (A61165)
2016 Nissan Sentra...
2016 Peterbilt 337 S/A Flammable Liquid Transport Truck (A60352)
2016 Peterbilt 337...
Mini concrete mixer (A61567)
Mini concrete...
