DK50SEHC glow plugs not working?
/ DK50SEHC glow plugs not working? #1
tractorsam
Member
New Germany, NS
Kioti DK45SE HST Cab
I just bought a new to me Kioti DK50SEHC and am trying to tidy it up a little. Currently the glow plugs do not work, when it’s cold and you turn the key on the indicator comes on for a short time, or if you turn the key past ‘on’ but before ‘start’ the indicator will come on. I found the glow plug relay on the front of the fuel tank and I have connection to the glow plugs and battery power to the relay. One of the control (small) wires to the relay is connected to ground. The mystery is that the other control wire has power when the key is on but it goes off when in the glow plug position, which seems opposite to what I would expect, otherwise I’d just replace the relay. Any thoughts? I did get a workshop manual with the machine but it is for a DK45/50 not the SE. Any reputable places where I might get the correct manual? Thanks, Sam
/ DK50SEHC glow plugs not working? #2
Pull out the glow plugs and test to see if a direct connection to a battery makes them glow after 5 seconds. If they are dead, the control may give up.
Good to know, thank you. Any reason I can’t just resistance test them? Thanks, Sam
/ DK50SEHC glow plugs not working? #4
The measured resistance sill be very low - perhaps half an ohm. The resistance in your ohmmeter leads can be that much. Put a voltmeter on one of the glow plugs with the other lead grounded. Activate the plugs and see if you get a reading and what the reading is. It should be about 10.5 volts. If you put twelve volts directly to a glow plug on the bench it will get very hot instantly - do not touch it.
/ DK50SEHC glow plugs not working? #5
Those relays are not like there labeled in maintenance book…there reversed. I found out the hard way. Have someone verify power to relay while holding key in glow pug position.
/ DK50SEHC glow plugs not working? #6
Not necessarily for your tractor but my mower requires a manual glow plug activation by rotating the key halfway between run and start after manually holding the key in that position for 10 to 30 seconds depending on the ambient temp., then turn the key the rest of the way to crank to start.
Thanks, the tractor automatically brings them on when you turn the key on if it’s cold. There is also a position on the key switch to manually actuate them.
I didn’t look in the book to determine which relay it was, I just traced the wire from the glow plug buss bar back up to the relay so I’m pretty confident I have the correct one. Thanks, Sam
Using my multimeter I got 0v at the glow plugs. That lead me to the relay. I’m just trying to figure out why it seems to be trying to power up the relay when the key is on but not in glow and taking the power away when the is in the glow position. Thanks, Sam
/ DK50SEHC glow plugs not working? #10
I believe thats controlled by the tractors computer box. I forget what the actual name of the unit is. I had mine replaced during warranty for some issues when tractor was brand new. I think it was called the display unit
edit: i did a search. Apparent kioti uses a glow plug timer relay. Not sure where its located. I have a 2010 model dk45 cab maintenance manual in the shop. Ill see if i can find out more about it.
/ DK50SEHC glow plugs not working? #11
Heres a nice thread on glow plug testing
Thank you. I have done some more testing, the glow plug relay (middle of the three on the RHS front of the fuel tank) is not receiving control power to make it activate to heat the glow plugs. If I manually trigger it then the glow plugs heat up.
My earlier testing where I had voltage on the control side was faulty as I was testing with an open circuit, once I tested with the relay plugged in I discovered I wasn’t getting any power to turn the relay on. This is the same whether the glow plugs are being manually actuated or via the controller. Is the item labelled ‘display module’ on the front of the fuel tank the glow plug controller? Thanks, Sam
/ DK50SEHC glow plugs not working? #13
I dont know if the display module control glow plugs. it has been 10 years since mine was replaced for another issue. They say theres a glow plug timer. I have not gotten home yet to check my manual
I did some further testing and have determined that the ‘display unit’ has failed. I have a glow signal coming from the key switch to the display unit, but no signal comes out of the display unit. Thanks, Sam
/ DK50SEHC glow plugs not working? #15
yes, i looked up in my service manual, the display unit is the device that controls glow plugs
Many thanks, I did some more testing and narrowed it down to the display unit, I ordered and installed a new one and now my glow plugs are working. Thank you.
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
2018 Kubota U35-4 (A64126)
2018 Kubota U35-4...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
