Valve issue ?
/ Valve issue ? #1
Mudfarmtruck
Member
Deere, kubota
Hello.
I’ve got a Kubota m100 with a quicke loader. I’ve re sealing the valve, and have tested the pump. It has pretty . When I hook the valve up to the 3 hoses and operate the spools , I have absolutely no pressure to my hydraulics. If rebuild the centre valve but I’m wondering if I don’t have it lined up properly. Help !!! Thanks
/ Valve issue ? #2
Hello.
Sir it sounds to me like the hoses are not plugged all the way in, or in correctly.
/ Valve issue ?
That’s something that Is overlooked . I will double check it , thanks
/ Valve issue ?
Still no results. Will be the day testing again
/ Valve issue ? #5
Post some photos of your valve, the three hoses involved, and explain where on the tractor each hose goes. Pictures from multiple angles will help identify what you need to know.
/ Valve issue ?
There’s pressure to the valve . The pump is pumping fine . Just not to sure why none of my spools are allowing fluid to my bucket … maybe it’s something simple , but I’m stumped
/ Valve issue ? #7
That joystick is a remote. It’s in the equation to.
/ Valve issue ? #8
And also my joystick has a lock on it
/ Valve issue ?
Yeah. Mine is joystick . It’s mechanical . Still no pressure
/ Valve issue ? #10
By the looks of that valve there's a good chance you could get something put in wrong. It's certainly not the simple two spool loader type valve we commonly see. I can't tell much about it from the single view but I don't see anything familiar about it. Maybe one of the smarter guys here will know what it is.
Was the problem there before you rebuilt it or after?
John Deere 344L Loader (A60352)
John Deere 344L...
2023 TAKEUCHI TL8R2 SKID STEER (A62129)
2023 TAKEUCHI...
Crestron CCS-UC-CODEC-200 Codec Video Conferencing and Collaboration System (A59317)
Crestron...
Striker TNB-4M Hydraulic Breaker (A60462)
Striker TNB-4M...
USC Series 2000 Conveyor (A61307)
USC Series 2000...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
