Ford 4500
   / Ford 4500 #21
Sitting looking at the backhoe, left to right.
#1 Dipper/curl - push goes out, pull curls in
#2 Boom - push goes down, pull comes up
#3 Bucket - push dumps, pull digs or curls up
#4 Swing - push goes left, pull comes right
Outside levers are the stabilizers/outriggers
Good news this is the same as mine! Having never used a set up like that (I wondered if over the years someone switched them around).
   / Ford 4500 #22
I was wondering what type of transmission I have I need to order a clutch for it but don't no what to get
   / Ford 4500 #23
6x4 w/Independent PTO, should be the following kit:
If you had the date code, ie: 4F14B, found on the RH ledge of the bell housing behind the starter, this will help.
   / Ford 4500 #24
These are the numbers I was able to try and get
   / Ford 4500 #25
Those are casting numbers. The model code, date code and serial numbers are "stamped" into the ledge on the right side of the bell housing top behind the starter. Also on the hood on a foil like label, but probably gone or illegible by now.
   / Ford 4500 #26
  • FORD CODES and SERIAL NUMBERS 1.pdf
   / Ford 4500 #27
Here is another set of numbers I will look into the ledge of the bellhousing behind the starter
   / Ford 4500 #28
That is the loader model, a 740, which is pretty common
   / Ford 4500 #29
Here are the numbers I got from behind the starter
   / Ford 4500 #30
Great old machines
Don’t get in a hurry they are slow by today’s standards
Last production on the 4500’s was 1974
Have 2 currently and will keep them as long as I live
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
Champion Vibratory Roller (A60462)
Champion Vibratory...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
