Kohler CH25s motor…what Spec?
/ Kohler CH25s motor…what Spec? #1
Modrob
Gold Member
Power Trac
My Kohler CH25s motor had a tag that listed the Spec number, but most of the label has worn away now…
How else can I find out what my Spec number is?
/ Kohler CH25s motor…what Spec? #2
I do not know. Maybe get the serial number off of your machine and call PowerTrac and see if they have a record of it?
I sent an email to Kohler…probably no help…LOL…I’ll see if I can find a serial number somewhere then give them a call. Thanks again!
/ Kohler CH25s motor…what Spec? #4
Captain Obvious here. The newer ones at least had 2 tags. Would it come up in your search history if you started to type it out?
/ Kohler CH25s motor…what Spec? #5
Mine is right here. Hope this helps.
(click to enlarge)
Talked to Keith at Power Trac earlier—he got me the needed info. 😊
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
FIXED FIFTH WHEEL ATTACHMENT (A60736)
FIXED FIFTH WHEEL...
Vertical Steel Well Tank (A61570)
Vertical Steel...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
