airbiscuit
Super Member
- Joined
- Aug 28, 2004
- Messages
- 7,533
- Location
- NW Wisconsin
- Tractor
- New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
As I understand it, your plan is:
This job will cost a bunch. I would recommend having another hand on the shore or in a boat to help and or for safety (small cost in the scheme of things) They can help in ways that are not foreseen in advance.
Can't you just stand up in the 3 feet of water as long as you are on the back side of the pile?
PSS: I don't think it is going to break away with all the logs stuck in the mud. Dislodging them from the mud will be the greater task.
- Worker on Bridge - Handle rope, hand down saws, sharpen chains
- You on Pile - cutting logs into small chunks, attaching rope to logs
- Operator in Excavator - Or is that you later?
- So is our plan to cut off all the tops on the pile (and let them float away)?
- Then winch/pull the logs stuck in the mud with the excavator?
- Then hope the current scours the rest of the silt/mud away?
) so many good ideas. If someone was really good with explosives, just enough breaking it loose, it would simply float downstream which it would anyway if it hadn't clumped up.
