Kubota B3030 just stopped running
   / Kubota B3030 just stopped running #1
desoto bill
kubota b3030
I was driving back up my driveway from spreading some gravel when my Kubota B3030 just stopped running. I checked and replaced the fuel filter, no water in the filter bowl, the glow plug light comes on, and the engine turns over okay but it just won't fire up. Where do I look next?
   / Kubota B3030 just stopped running #2
Welcome. Where are you? Cold? Does the fuel POUR into the filter bowl (with it removed), or just dribble? If not flowing good, blow air back up to the tank (take the cap off first). You may have algea/gunk/ice up there.
   / Kubota B3030 just stopped running #3
That’s a good one. All the safety things appear to be working because it turns over. Full of fuel? Getting air? Is the electric shut off working. Fuel to injectors? That’s some things to check
Thanks for the response. I'm in Virginia, temps were in the 50F range. Fuel flows freely into the bowl.
Thanks for the response. I did also check the air filter and the front grill screen to make sure they weren't clogged.
   / Kubota B3030 just stopped running #6
I would be checking the fuel shut off solenoid that mike1955 mentioned. First check the fuses, then the solenoid operation.
2016 Mercedes-Benz GL-Class SUV (A50324)
2016 Mercedes-Benz...
91013 (A48082)
91013 (A48082)
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
