BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,472
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
I finished out the year by getting the right side fender installed and aligned, and inner fender installed. The fender wasn't too bad to get adjusted and aligned, but the inner fender was a pain in the ass. The radiator support, fender and inner fenders are all new parts from Auto Metal Direct, and for the most part, they were well made parts, but like any repop auto parts, they don't always fit together perfectly. Just getting the inner fender in and in place was like solving a puzzle, but once I did get it into place, I was able to get seven of the nine bolts in and started fairly easily. One of he last two, the one farthest to the front below the marker light, bolts the radiator support, inner fender and the fender together, so getting the holes in all three pieces lined up was a real treat, and even then the bolt wouldn't start straight, but I finally got it in and tight, The other one that is on the inside of the fender at the front of the wheel opening was a bear. Initially, there was an inch gap between the mount on the fender with a welded nut, and the hole in the inner fender. I finally had to use a couple of 1/4" bolts and washers to pull them together enough to get the proper bolt in and tight. The final piece was a brace that hold the bottom lip of the fender to the radiator support, and that went in pretty easily. But, I got all the bolts in and tight and it looks good.
I'm considering assembling the left fender and inner fender before I mount them to the car as a couple of guys on Steve's Nova site have recommended. If I do that though, I'll have to have someone help me get it on the car. I have a couple of other things I can do while I decide on that though.
It's New Year's Eve, so I hope everyone has a good time and stays safe and well, and have a great 2024!
