Shear pin nightmare
/ Shear pin nightmare
When you shut it down to use the bucket - water/slush refreezes - - somewhere. Don't shut it down. Does not hurt a thing to keep it running.
I use to have a 3-point blower. Any time I had to blow anything less than dry, fluffy snow - I could have the same experience. Just about anything would blow a shear pin on mine. Ice chunk, frozen slush, limb, stick, frozen pocket gopher - you get the idea.
Going to a higher grade shear pin IS NOT the answer.
I hear you, not comfortable with a grade 3 bolt anyway. Frustrating ! Thanks for sharing your experience.
Two possible issues:
1. Shear pins you are using may be the wrong grade (too weak). Check the manual to see what grade they shoukd be.
2. The slight moisture that builds up around the fan that shoots the snow up through the chute while it’s running (melting particles of snow due to friction ) can freeze up quickly when you stop for a minute while you’re snowblowing. That happens to the blower on my skidsteer (which is all hydraulic; no shear pins). I carry a small ten pound hammer in the cab and give the fan blades a few quick heavy whacks to break the ice bond. It works.
My guess your main issue is the quick freeze up described in #2 since it only happens when you engage the pto after having run it for awhile. Keep a hammer under your seat and give the fans blades some strong whacks; it won’t hurt them.
Hi, gonna try spraying WD-40 inside the tunnel and all over impeller just to see if it makes a difference. We are expecting 6" snow Friday, Nothing ventured Nothing gained !
/ Shear pin nightmare #24
It doesn’t help; anything you put on (other than paint) is gone in the first few minutes of use.
The hammer is the simple and easy solution.
/ Shear pin nightmare #25
Fluid Film works, but is pricy in large quantities. Guess what I do? I get a pack of Crisco shortening in brick form and I just rub that liberally all over the snow contact surfaces. Re-apply between sessions. It does NOT return to the kitchen. Food grade, won't hurt a thing.
/ Shear pin nightmare #26
Hard to believe your brother used it for years without shearing a pin.
/ Shear pin nightmare #27
I Always lower rpm to about 1500 and lower blower to the group. Once it starts working , I bring it up to 2500 rpm. Right now, thawed out, every in neutral spins very nice. No rubbing anywhere. And yes , electric pto. Thanks for your input
Could that be the problem? Try dropping the RPM all the way down before disengaging & engaging.
On the shear bolt, I have a 60" HD blower on the front of my 3039R and it has 1/4" grade 5 shear bolts.
/ Shear pin nightmare #28
I also wonder about the JD electric engage PTO since the person I purchased by blower from had JD and he complained about constantly breaking shear pins. Had the blower 3 or 4 years now and broke one when hit a chunk of ice. My tractor has mechanical PTO engagement via the clutch.
/ Shear pin nightmare #30
The OP must be confusing Grade 5 bolts by calling them Grade 3?-for 3 hash marks on the head.
Grade 2 usually make lousy shear bolts because they seldom break cleanly and tend to help elongate the hole.
Wonder what Erskine recommends?
/ Shear pin nightmare #31
Manual calls for grade 2
/ Shear pin nightmare #32
I also have that same problem with my hydraulic unit. If I shut it down and road the tractor between jobs, it freezes up if the weather is just right. I have to get out and I carry a 2x4 with me to manually wedge the center rotor while tractor is off. Then I get back on and it runs great. If I don’t do that, the hydraulid bypass kicks in and nothing turns. Only happens when temp is near freezing …..doesn’t occur when super cold. I guess the snow has to melt some and get behind the fan. Than freeze again.
also, glad I do-not have shear pins anymore. I went thru 100’s of them before this rig.
/ Shear pin nightmare #33
Thanks for the photos.
The blower was originally used on a ford tractor and now is on a different one.
Was the length of the pto checked so there is no bottoming out when blower raised and there is sufficient overlap.
Dave M7040
/ Shear pin nightmare #34
My guess is that the electric PTO switch is unforgiving of any ice buildup.
Re-engage the PTO at absolute low idle.
/ Shear pin nightmare #35
Also has the gear oil been changed recently? Yearly is recommended. Not because the oil is worn out, but the high chance that it’s got moisture in it due to condensation. The moisture may be freezing up inside the gearbox causing the issue. I use a synthetic Marine gear lube in my blower…😉
/ Shear pin nightmare #36
Leave your shear bolt a little loose use a stover nut or double up nuts
Will bend but not break right away anyway. Tightening them down makes them pop
/ Shear pin nightmare #37
If the shear bolt breaks, make sure to always replace it with a same category bolt (grade 8.8). It is necessary to
always maintain this bolt very tight, in order to keep the efficiency of the shearing mechanism
...appears to refer to a metric grade 8.8 bolt. I think that is roughly the same as an SAE grade 5 😬
To Dman above, That’s opposite to what my manual says. Shear bolts are to be tightened snug. However not like a gorilla would, as it would already be primed to break if done like that….
/ Shear pin nightmare #38
I like using stover nuts, even though they are expensive. I also have good luck with nylock nuts and a drop of Loctite. But the shear bolts should ALWAYS be drawn down with the proper torque.
The last thing we want is for the bolt to be loose.
/ Shear pin nightmare #39
That's for sure enough loose nuts behind the wheel already
/ Shear pin nightmare #40
One thing I’d make a good inspection of is the Shear coupler itself. Pull it off the tractor pto and with the shear bolt removed see how much wiggle, play and slop there is between the two rotating halfs. Over the years vibration in the driveline can cause excessive wear to it.
Have you ever checked to see if the shear bolt is staying snug after a hour or two of use? I had a Loftness blower quite few years back probably had good 1000hrs on it and the pto shear coupler was getting worn and sloppy. Two problems it caused was shear bolt to self loosen and sometimes back itself all the way out or break the shear bolt upon the quick Electronic engagement.
Running the the blower tipped at a slight angle will throw the tractor pto shaft and blower gearbox shaft out of parallel increasing the vibration wear to this shear coupler.
John Deere 608C 6 Row Corn Head (A64119)
John Deere 608C 6...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
iDrive TDS-2010H...
2018 International WorkStar 7500 T/A Matador 4,500 Gallon Septic Wet Vacuum Truck (A61573)
2018 International...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
